Right front blinker stays on when lights are on.
Old May 7, 2022 | 06:59 PM
Vics86's Avatar
hey guys,
so im putting all new bulbs in the 72 to start and diagnose any light issues. Right now I cant get the right front blinker light to go off while the lights are on. When headlights are on the right blinker stays on solid, no blinking.
It works and blinks when I use the blinker, I was thinking of just buying a new light blinker assembly. The ground in the front looked pretty good, I sanded down the metal and reattached and nothing improved.When i disconnected the ground from the front frame the blinker light stayed on
What do you think?
Old May 7, 2022 | 07:51 PM
armbrbr's Avatar
My guess would have been a bad ground,but it sounds like you looked at that. My next guess would be the wrong bulb, I think that one is supposed to be an 1157 A.
Old May 7, 2022 | 08:39 PM
70W-32's Avatar
When the headlights are on, both parking lamps should be lit.
Old May 7, 2022 | 08:57 PM
Yeah, maybe the issue is with the other side that isn’t lit when the headlights are on. Check for a burned filament in the bulb on that side.
Old May 8, 2022 | 03:48 AM
Yep parking lights should be on with headlights. Check with parking lights on only ( 1st indent out on headlight switch) then only park lights and taillights should be on. Older cars had park lights only on 1st indent- then headlights only on all the way out, but by 72 all 4 should be on with switch pulled all the way out. Changed in , what, 66 or so???
Old May 8, 2022 | 06:04 AM
Vics86's Avatar
thanks for info! now i didnt know the blinker lamps were supposed to stay on when lights are on. maybe its the ground on the other side then.
can the wire in the ground go bad or is a typical bad ground that which isnt making proper contact to frame?
Old May 8, 2022 | 08:00 AM
70W-32's Avatar
Typically its the ground to the frame, but it can be a broken wire, or a rusted connection, or gunked up socket
Old Aug 7, 2022 | 09:06 AM
Vics86's Avatar
just for future reference, i did get the lights working correctly. I messed with the connectors and did the bast I could cleaning them. That has done the trick so far. Just out of knowhere the left front parking/blinker light came on and when I jiggled the line it would go on and off. So cleaned up connector and its working now.
Old Aug 7, 2022 | 09:56 AM
Sugar Bear's Avatar
Do you have the small ground wire from the negative battery cable to the fender?
Tiberian Fiend
Dec 10, 2018 01:32 PM
Tony72Cutlass'S'
Aug 16, 2017 05:15 PM
805Cutlass
Nov 3, 2012 03:00 PM
gdcheese
Oct 7, 2011 03:24 PM
projectheaven
Jan 5, 2008 07:01 PM
