hey guys,
so im putting all new bulbs in the 72 to start and diagnose any light issues. Right now I cant get the right front blinker light to go off while the lights are on. When headlights are on the right blinker stays on solid, no blinking.
It works and blinks when I use the blinker, I was thinking of just buying a new light blinker assembly. The ground in the front looked pretty good, I sanded down the metal and reattached and nothing improved.When i disconnected the ground from the front frame the blinker light stayed on
My guess would have been a bad ground,but it sounds like you looked at that. My next guess would be the wrong bulb, I think that one is supposed to be an 1157 A.
Yep parking lights should be on with headlights. Check with parking lights on only ( 1st indent out on headlight switch) then only park lights and taillights should be on. Older cars had park lights only on 1st indent- then headlights only on all the way out, but by 72 all 4 should be on with switch pulled all the way out. Changed in , what, 66 or so???
just for future reference, i did get the lights working correctly. I messed with the connectors and did the bast I could cleaning them. That has done the trick so far. Just out of knowhere the left front parking/blinker light came on and when I jiggled the line it would go on and off. So cleaned up connector and its working now.
