heads
Old Feb 22, 2022 | 11:52 PM
michael l's Avatar
heads
are #5 heads better than #7 heads.
Old Feb 23, 2022 | 04:33 AM
bccan's Avatar
To a large extent, 6 of 1 to half a dozen of the other. 7’s have hardened exhaust seats with rotators on the exh valves in stock form . AFAIK they are dimensionally the same in the ports and chambers.
Old Feb 23, 2022 | 06:27 AM
^^^THIS. Note that the "hardened" seats are not inserts but just induction hardening of the parent metal cast iron. This hardening is very shallow and pretty much gets removed the first time you cut the valve seats, so that really isn't a discriminator. The rotators mean that the #7 heads have deep spring pockets on the exhaust side, which will require shims under the springs if you plan to delete the rotators to reduce valvetrain mass.
jimmymtfan19
Dec 19, 2016 10:23 AM
Oct 2, 2016 08:09 PM
The Bug Man
Oct 25, 2013 08:37 AM
agtw31
Jun 4, 2009 08:35 AM
