Window channels/sweeps
Who makes the best, most correct window sweeps both interior and exterior? I’m thinking there must be more than one manufacturer of these? And while we are at it, what about weather stripping products? Soft seal, Steele etc…
I picked up my sweeps and weatherstripping at OPGI.
Right out of the gate I will tell you that you will spend more there than other sites, but I've never had a fitment issue or had to re-cut or bend anything that I bought from them. Everything fit perfect.
Curious who supplies theirs?
Last time I checked there were two styles on the market.
One company had OEM factory-style finished stainless ends, same fuzzy & rubber material.
The other(s) were not finished correctly on the stainless ends but the rubber and fuzzy were OK. On these, the stainless ends appear to be simply cut to length and not properly finished(rounded) per OEM...obviously cheaper.
Steele Rubber Products - Window Felt Beltline Weatherstrip Kit | Auto Restoration | Steele Rubber Products
Here's an option. I've dealt with them on weather stripping and what they provided was correct for my 69.
