Paint Stripper New Formula Sucks!
Old Nov 5, 2021 | 07:36 AM
Oldsmaniac's Avatar
So from time to time I use paint stripper during a restoration, Zip Strip seems to work well. I had a bit left in the metal can and it worked like a charm. When I went to a local Hardware store I saw the Zip Strip in plastic bottles, new formula it seems but label says works fast. I bought the bottle and returned to the job, laid out a nice coating and waited, waited, WAITED with not even a hint that the paint was lifting. I also have some experience with the Citrus formula...its a joke. My last resort will be the Aircraft stripper sold at the chain stores. Hope they don't mess with that!
Old Nov 5, 2021 | 08:04 AM
Tedd Thompson's Avatar
I have had good results with Aircraft Remover, when in doubt look to see if it contains methionine chloride that is the active ingredients that makes it work, most of the other ingredients slow the dry time down, so it has time to work..... Tedd
Old Nov 5, 2021 | 08:12 AM
redoldsman's Avatar
Proud Viet Nam Veteran
It has been lots of years since I used aircraft stripper but in some cases it was the only thing that would work. It is nasty stuff and you needed gloves and good ventilation. I am glad those days are over.
Old Nov 5, 2021 | 08:14 AM
BSiegPaint's Avatar
As of November 2019, methylene chloride is illegal to sell for retail use, unfortunately. I've found that Aircraft Stripper still does a good job despite replacing the MC with other chemicals.
Old Nov 5, 2021 | 06:46 PM
ELY442's Avatar
I use Rock Miracle.
Old Nov 5, 2021 | 08:51 PM
edzolz's Avatar
Kind of expensive, but Easy Off oven cleaner works overnight. Spray it on and cover it with Saran Wrap to keep it from drying out so fast.
67Rocket
Body work
Jun 14, 2016 08:20 AM
olds 307 and 403
Wheels and Tires
May 1, 2016 09:09 AM
1970442
Jan 14, 2014 06:44 PM
mugzilla
Jun 26, 2009 11:13 PM
derek nesdoly
Jun 25, 2009 03:02 AM
