I've got a 1964 J88 that had a 2bbl on it. I ended up with a 4bbl intake from a '72 350 and a donated qjet. I mistakenly jumped into the swap before I figured everything out and now I'm stuck on how to get the linkage hooked up. I know '72 was a cable set up where currently I have hard linkage. Would I need to swap my pedal over to work with a cable or is there a way to make it work? Thanks
