20 teeth or 19 teeth?
Old Dec 4, 2020 | 08:52 AM
W-27's Avatar
Replacing my differential with one that has different gear ratio's and wondering which one to purchase. I have 3:23 to 1, M-20 4 speed transmission (don't know the amount of teeth of plastic gear inside the transmission) 20 teeth speedo gear (Blue) wheels are 26" total diameter but if measured from center to outer edge it's only 12 1/2". Do i go 19 or 20 teeth? Were can i get one made in the USA? Thank you in advance.
Old Dec 4, 2020 | 09:36 AM
https://www.tciauto.com/speedometer-gear-calculator
Hopefully this helps. You need to know the gear ratio, tire diameter, and either the drive or drive gear tooth count. This will calculate the other gear needed. Play around with different tooth count, you want to come up with a combination that has the closest whole number. You can’t have a gear with 19.5 teeth! The closer to a whole number, the more accurate the speedo.
Old Dec 4, 2020 | 11:54 AM
W-27's Avatar
Everything that i know is listed in the thread. Gear ratio is 3:23 to 1, M-20 4 speed transmission, wheels w/tires are 26" diameter but if measured from center to edge of tires it's 12 1/2" the only thing i do not know is the tooth count inside the transmission (originally 3:23 to 1 M-20 4 speed).
Bfg
Jan 14, 2020 12:53 AM
Docs72
Oct 8, 2019 08:02 PM
olds 307 and 403
Apr 6, 2018 07:49 PM
4SPEED67
Feb 21, 2018 05:41 PM
W-27
Drivetrain/Differentials
Aug 13, 2013 01:05 PM
