1965 Cutlass instrument cluster
Hi all, I have posted in the past regarding my problem with my right turn signal dash blinker not working. I have determined the fault is in the circuit board. I can not see if there is a tear in the copper foil to that socket. Has anyone removed only the circuit board from behind the cluster or am I looking at removing the whole cluster? Has anyone repaired these boards?
At the risk of being a smart-***, with a soldering iron. It's just copper PWB. Make sure the copper is clean, that any over coating is removed, and be as quick as possible to avoid damage to the underlying plastic. If you are not proficient at soldering, find someone who is or risk damaging the plastic substrate.
