1965 Cutlass instrument cluster
Old Aug 31, 2020 | 06:05 AM
Bfg's Avatar
Bfg
Hi all, I have posted in the past regarding my problem with my right turn signal dash blinker not working. I have determined the fault is in the circuit board. I can not see if there is a tear in the copper foil to that socket. Has anyone removed only the circuit board from behind the cluster or am I looking at removing the whole cluster? Has anyone repaired these boards?
Old Aug 31, 2020 | 06:12 AM
If you are asking about removing the printed circuit while standing on your head under the dash, no. Pull the cluster and work on it on the bench.
Old Aug 31, 2020 | 08:11 AM
miksan's Avatar
miksan
X-2
Old Aug 31, 2020 | 11:39 AM
Bfg's Avatar
Bfg
Ok, so after the cluster is removed is the copper foil repairable if that is the problem?
Old Aug 31, 2020 | 11:44 AM
A break in a copper trace can be fixed with a soldered jumper wire. This is extremely common PWB repair. If it's a broken or loose pin to the connector, that's a different problem.
Old Aug 31, 2020 | 11:55 AM
Bfg's Avatar
Bfg
I know it’s not a broken or loose pin. So how exactly do I solder this?
Old Aug 31, 2020 | 12:02 PM
At the risk of being a smart-***, with a soldering iron. It's just copper PWB. Make sure the copper is clean, that any over coating is removed, and be as quick as possible to avoid damage to the underlying plastic. If you are not proficient at soldering, find someone who is or risk damaging the plastic substrate.
Old Aug 31, 2020 | 12:23 PM
Maybe a soldering pencil, something small and low powered.
Old Aug 31, 2020 | 12:35 PM
Bfg's Avatar
Bfg
I haven’t done much soldering where I would feel comfortable, so I would most likely have it done by someone who is more familiar. Thanks Joe
Bfg
Aug 12, 2020 01:03 PM
brandon reynolds
Feb 28, 2019 02:09 PM
HonestDave
Jul 26, 2014 07:08 AM
StarGeneral
Jan 25, 2012 09:19 AM
slowolds
Jun 28, 2009 06:55 AM
