Baldor motor
Old Jul 26, 2020 | 09:04 PM
11971four4two's Avatar
MOTORHEAD
Baldor motor
Today the VACU BLAST burned down
Thought it was a dust return or beads hose burst
SMOKED EN
In the FM I will try and fid VIN TAG for RPM 220V and ****
Hey
How are you?
I really hope you are having a great day
CHEERS
brian
Old Jul 27, 2020 | 12:17 PM
Bernhard's Avatar
Motor and electrical fires are nasty!
Explosion proof motor?
Old Jul 27, 2020 | 12:22 PM
MOTORHEAD
I have not dug into it yet. I would not be surprised as it is in a dusty environment. I am glad garage did not burn down! I shut it down as soon as I saw smoke. It never did trip / blow the breaker.....
My guess is it will be expensive to fix...
Old Jul 27, 2020 | 01:25 PM
MOTORHEAD
L 1402 so far have not been able to find on Baldor Catalog May be obsolete??
Old Jul 27, 2020 | 02:12 PM
If you have an armature type shop locally they may be able to rebuild the motor for you.
Old Jul 27, 2020 | 06:37 PM
Also, no need to get exactly same motor, as long as same size and power.
Old Jul 27, 2020 | 07:20 PM
69HO43's Avatar
Airtight fan motor....1.5 hp same RPM and single phase. Worth checking out???
https://www.mile-x.com/baldor-afl352...hoCCB0QAvD_BwE
Old Jul 27, 2020 | 07:27 PM
oldolds88's Avatar
when the magic smoke gets out,you cant get it back in
Old Jul 27, 2020 | 07:42 PM
RetroRanger's Avatar
72 Olds CS
we needed a similar type motor at work, we found a compatible replacement at granger ours was a weird shaft too.
Old Jul 28, 2020 | 01:10 PM
MOTORHEAD
Spent the morning on the phone and found no direct replacement available.
Something close with adapter mount / base $600 But it "should fit" not very reassuring to my ears.
I did find a local shop that will look at the motor and repair for $300 or less was the estimate
I managed to get the motor and the "blower / impeller" section of the machine removed and so far cannot get thing apart. It is HEAVY
I would imagine price will just go up if I bring motor in like it is now.
Thanks for all the ideas / input
Old Jul 28, 2020 | 02:20 PM
cjsdad's Avatar
Smoke Pumps usually cost about the same as replacement parts...
warnej21
Feb 2, 2014 07:45 PM
sx455raidercelticfan
Non-Olds Engines
100
Dec 4, 2010 10:47 AM
tyler_s
Sep 20, 2010 05:25 PM
<thumbs60>
Nov 3, 2003 07:15 PM
<thumbs60>
Nov 3, 2003 07:06 PM
