1967 442
Old Jun 10, 2020 | 09:36 AM
442gs's Avatar
1967 442
any factory specs on rear coil springs.
Old Jun 11, 2020 | 08:24 PM
442gs's Avatar
ordered a set of #5389 142 lbs to replace my #5385 168 lbs that sat to high and wheel hop. #6321 were to soft at 119 lbs i would think.
Old Jun 12, 2020 | 07:46 AM
69CSHC's Avatar
Sorry pal I didn't notice this thread till just now. Not sure if this helps and obviously its a little late but here goes.
http://www.oldsmobility.com/old/imag...hics/mmp19.jpg
Old Jun 12, 2020 | 10:35 AM
442gs's Avatar
great thank you so much. if am reading it right its a part # 9787050 that comes out to 122 lbs. or is it #9787048 for the 4-speed ?
Old Jun 12, 2020 | 07:33 PM
69CSHC's Avatar
9787050 is the HD 442 spring and would be firm, 9787048 is lighter duty.
This list verifies. http://www.oldsmobility.com/mpc/group7000/text04.htm
I think you chose wisely, I cant locate a part with # 5389 but I did locate the other 2 you listed, matching weight specs you provided.
Looks like 140 lbs is factory HD. Post 12 in this thread, https://classicoldsmobile.com/forums...springs-40898/
#5385 has the reputation you experienced. Post 4 same thread above.
This thread may also be of interest to you, particularly post 15. https://classicoldsmobile.com/forums...springs-36321/
P.S. here is QA1 spring rate information. 1964-1972 GM A-body
Soft is 130, Medium is 150, Firm is 175, https://www.qa1.net/assets/uploads/d...le-Weights.pdf
Old Jun 13, 2020 | 03:45 AM
442gs's Avatar
the 5389 is 12.6 free height. 142 - 737 - 7.5 installed height .554 coil size. getting them from springs&things, someone is making them again. should lower the height 5/8" to 3/4" over the 5385. let you know next week.
hope to get the back down a little
Old Jun 18, 2020 | 11:37 AM
442gs's Avatar
wow what a difference, better ride, better handling and no more wheel hop. it lower it 5/8 of an inch. i will get another photo in same parking spot. wouldn't want it any lower.
Old Jun 18, 2020 | 03:23 PM
69CSHC's Avatar
Excellent, how sweet it is when you are hoping for a specific result and you nail it.
Money well spent, look forward to new pic.
Old Jun 19, 2020 | 04:24 PM
442gs's Avatar
whats looks better ?
Old Jun 19, 2020 | 06:47 PM
otto72's Avatar
subtle 100% better. Nice
Old Jun 19, 2020 | 06:56 PM
Agree. Much nicer profile.
axle1320
Jun 5, 2020 09:33 PM
not2old
Jul 8, 2019 05:45 PM
not2old
Jun 22, 2018 06:44 AM
Insom
Jan 21, 2010 12:11 AM
