carburetor size?
Old Apr 27, 2020 | 01:17 PM
BLUZIN's Avatar
carburetor size?
A question if the Edelbrock 1406 is too big? Stock was a 2 barrel carb. and previous owner put the 4 barrel edelbrock on. It works, but is there a better match? Original 2 barrel intake manifold , 72 Cutlass supreme, 350-2 barrel, single exhaust. Looking to go dual exhaust near future. Thanks, Jack
Old Apr 27, 2020 | 01:23 PM
The internet shows that is a 600 cfm carburetor, so no it is not too big. The factory QuadraJet for that engine was 750 cfm. Vacuum secondaries will tailor the air flow for the engine demand. With whatever carburetor is used, you need to ensure the jetting is correct for the proper air-fuel ratio.
Old Apr 27, 2020 | 02:41 PM
ach1992880's Avatar
So you have a 4 barrel on a 2 barrel manifold? There are adaptors that make this possible, but you aren't getting the full benefit of the 4 barrel if that is your setup. I would personally go with a stock 4 barrel manifold with a qjet, but even a stock 4 barrel manifold with an adaptor for your edelbrock would be beneficial for you.
Old Apr 27, 2020 | 03:12 PM
shiftbyear's Avatar
Could you post a picture of your current setup, I've never seen what you are describing. Very curious.
Old Apr 27, 2020 | 03:52 PM
Yeah it sounds quite ghettofabulous.
Old Apr 27, 2020 | 03:55 PM
BLUZIN's Avatar
Yes, that's being adjusted now. Saying its a 2 barrel intake...??? I'll post a pic.
Old Apr 27, 2020 | 04:06 PM
BLUZIN's Avatar
coming now...
Old Apr 27, 2020 | 04:58 PM
BLUZIN's Avatar
Manifold
Old Apr 27, 2020 | 05:00 PM
BLUZIN's Avatar
Only pic I have right now. Ill get a better on tomorrow.
72cutlassdog
Jun 16, 2017 09:56 AM
yeahbuddy
Jan 17, 2011 11:20 AM
KevinBN7
Dec 26, 2010 06:11 PM
72CUTTY
Feb 2, 2008 04:44 PM
bcg88
Mar 8, 2007 02:39 PM
