M/T Valve Covers
Old Mar 26, 2020 | 04:26 PM
skyhigh's Avatar
1972 Cutlass Town Sedan
M/T Valve Covers
Hi can anyone help me out with the right grommets sizes for these type of covers, I wanna run a proper pvc and breather on the other side, I'm gonna have to fab some sort of baffles up by the looks of it. some links to places to buy would really help, these are the ones I'm gonna buy tomorrow.
Old Mar 26, 2020 | 08:14 PM
70Post's Avatar
Those are made to work with original/factory rubber grommets. For example, that's a factory style rubber PCV grommet in your pic.
You can get the grommets from the typical Olds repro parts vendors.
Just be super careful when cutting away the "uncut" cover for the breather grommet. I've seen a lot of these M/T covers where someone hogged out the hole way too large and didn't leave enough of a lip to hold the grommet in place. The breather grommet you want is a "D" shaped grommet...like the PCV grommet is.
Old Mar 27, 2020 | 01:59 AM
rocketscientis's Avatar
ISO single solitary mickey RAC
M / T Rocker arm covers as name idicates....should b plural
mine is not
Should you happen across one let me know as th total loss oil system on my old Harley is factory original...but not on the 442
Old Mar 28, 2020 | 04:38 AM
oldolds88's Avatar
(problem) has 1 cover..needs 2 (covers)....does not want oil leaking out (humor)
Old Mar 28, 2020 | 07:45 AM
skyhigh's Avatar
this might make sense to you, but I personally have no idea what your saying here.
Old Mar 28, 2020 | 04:32 PM
skyhigh's Avatar
S.O.S pad brought out the shine
Old Mar 28, 2020 | 05:27 PM
oldolds88's Avatar
translating from omishjon to regular words omishjon is rocketsientis
Old Mar 28, 2020 | 05:31 PM
Shinny is nice
What would you recomend to shine th cover I need that I dont have ?
want to thank all for th help.. ..& whater th other stuff is as well...
Old Mar 29, 2020 | 03:08 AM
skyhigh's Avatar
sandpaper, start mild, moving up to a fine paper as you go along, finish it off with 0000 steel wool, all i did was 180 grit and a s.o.s pad, I have alot more finer sanding to do, then swap the old red for a nice coat of gold. I did order some new dorman grommets, and a pvc valve, hope there the right size, might take a while to get to the door due to the COVID panic.
Old Mar 29, 2020 | 03:11 AM
skyhigh's Avatar
yes, makes total sense now lol, sorry about that.
Old Mar 29, 2020 | 03:25 AM
Interesting now riddle me this o polisher of the part
How am I supposed to hold the RAC I cant see , same 1 I dont have , that I need to make my single M/T - RAC into a pair , to cover all 16 of th rockers to guide oil down passageways back to the pain while I am performin your ingenius proceedure on polishin Rocker Arm Covers I dont have , that I need . . . . . . . .
Anxiously Awaitin your reply....
Old Mar 29, 2020 | 03:49 AM
Translator to parts wanted
request for translator in parts wanted
unless your in parts unknown
We hav a situation , could turn into misunderstanding /or an understanding its touch & go.....aproach with blatent disregard for what thread is for & spread peace & wisdom to all , or your usual crap....
Better hurry dont know how long I can keep confuzed...
Sporty45
May 19, 2015 03:39 PM
FTW65W29
May 7, 2015 08:27 PM
Stevec
Jan 23, 2014 03:09 PM
slaughter442
Feb 4, 2013 04:08 PM
Doomah
May 11, 2012 11:08 PM
