Shifter help
Old Mar 9, 2020 | 02:59 PM
Tymiles24's Avatar
Shifter help
Replacing the aftermarket crap someone put in my 66 cutlass floor shifter..found a nice one to replace it but transmission shop says the handle wont work with the bracket..any ideas or help would be greatly appreciated.
Old Mar 9, 2020 | 03:42 PM
nicks1966's Avatar
The only thing I see is the shiter, like most of the 64 to 66 ones is broken, so you cant use the T Handle. You would have to use a shiftworks replacement for the handle
https://shiftworks.com/collections/c...le-replacement
Not sure what they mean by, it wont work with the bracket, it appears you have all of the correct linkage.
If you want a picture of an unbroken one let me know.
Old Mar 9, 2020 | 03:49 PM
Tymiles24's Avatar
the handle from the 68 wont match with the bracket from the 66. I think only a 65-67 will probably work.
Old Mar 9, 2020 | 04:05 PM
nicks1966's Avatar
The ears are broken off the handle and the roller and links are also missing. only way i know to make it work will be the shftworks kit.
Old Mar 9, 2020 | 04:27 PM
Tymiles24's Avatar
I should have took better pictures when I was down there but apparently it needs to have the bracket for the neutral safety switch
Old Mar 9, 2020 | 04:35 PM
nicks1966's Avatar
The neutral safety switch is on the shifer in the picture, 64 to 66 floor shifters use the same switch as the column shift cars.
Old Mar 10, 2020 | 06:27 AM
Your 66 shifter is broken, as are nearly all of them today. There is no easy fix. While I have not personally tried it, some people have successfully swapped in the shifter from a G-body Olds, which looks very similar to the 64-66 shifter.
442crzy
Jul 17, 2023 07:05 PM
Tymiles24
Mar 10, 2020 06:25 AM
froggys86
Sep 5, 2016 10:53 PM
froggys86
Apr 14, 2016 09:22 AM
