SpeedHut Gauge
Old Nov 22, 2019 | 07:57 PM
pettrix's Avatar
SpeedHut Gauge
For a 1972 Olds, what size are the OEM gauge pods? Is it 3 3/8" ?
Speedhut sells a 3 3/8" Quad gauge that has the Fuel Level, Water Temp, Oil Pressure & Voltage in a single pod. It's a nice and clean install and style. Anyone have this gauge?
Old Nov 23, 2019 | 06:14 AM
Dave26's Avatar
I did the complete change..... all three gauges, using Speedhut. I purchased 4", Here are some pics.
Old Nov 23, 2019 | 09:14 AM
pettrix's Avatar
Does the 4" gauge fit in the factory hole without any issues?
Old Nov 23, 2019 | 11:06 AM
Dave26's Avatar
I installed them behind the factory bezel. I made mounting brackets out of sheet metal. I used the original gauge as a template....mounting "ears" and all. cut the 4" hole. Placed the gauge through the hole in the sheet metal, the used Speedhut's mounting ring to hold it in place. Using the original as a guide, I drilled holes in the same position to screw into the dash. The OEM bezel fits over the top of everything. Yes 4" is the correct size. When you take your bezel off you will see how large the original gauges are.
Old Nov 23, 2019 | 02:43 PM
budg's Avatar
I was looking at those exact gauges . Now I know how they’ll look. They look awesome. Thanks for posting. On my short list now.
Old Nov 23, 2019 | 02:54 PM
Frisbee_k9's Avatar
Same as David 26
the builder of my ‘68 442 did the same gauges as David 26. He put in the GPS speedo which is a smart move.
Old Nov 23, 2019 | 05:12 PM
pettrix's Avatar
In regards to the Speedo MPH GPS. Does it also calculate 1/4 mile times?
Does the GPS track vehicle info/locations and keep records of it?
Old Nov 23, 2019 | 06:54 PM
Dave26's Avatar
Yes......and I don’t know about the second question......BTW, The tach is multi function.
Old Nov 24, 2019 | 04:24 PM
ach1992880's Avatar
I have Speedhut 3 3/8" gauge set in mine. They have been working great for 5 years. I did have the oil pressure sending unit go bad on me and they shipped another out same day. Great company to deal with, very customizable gauges and they look and work great. I do regret not getting 4" ones though.
Old Nov 24, 2019 | 07:55 PM
pettrix's Avatar
I will go with the 4 inch for better viewing size.
When the oil pressure sending unit went bad, did it scare you? I assume the oil pressure should zero, which one would assume is an engine failure, not a gauge failure.
Old Nov 25, 2019 | 01:21 PM
ach1992880's Avatar
When the sending unit went bad the gauge would spike to 100psi whenever the engine was running. I wasnt concerned about it because my engine is only a couple years old and has always carried good pressure.
Old Nov 26, 2019 | 08:12 AM
Levellord's Avatar
I took speedhut also, but I mounted them direct in the bezel, I found it hard to align behind. If you do it this way, dont take 4“ because you have to enlarge all holes which is not so funny.
Old Nov 26, 2019 | 10:26 AM
Dave26's Avatar
I really like the way that turned out
Old Nov 27, 2019 | 08:03 PM
pettrix's Avatar
I am a little confused. So will the 4" fit in a 1972 Cutlass OEM gauge pod? Or will I have to get the 3 3/8"?
Old Nov 28, 2019 | 12:00 AM
Levellord's Avatar
If you mount it behind the bezel, as Dave did and as the original is, 4“ is ok. For this you have reproduce the original mounting situation. If you choose the easy way and mount it through the bezel like I did, I would suggest to take a smaller diameter, 4“ will not match the holes in the bezel.
Old Dec 30, 2019 | 02:29 PM
pettrix's Avatar
Do you have any pics of the sheet metal bracket that you created to mount the gauges?
Old Dec 30, 2019 | 03:53 PM
cdrod's Avatar
Rodney
Pettrix:
The 4" SpeedHut gauges will fit behind the stock bezel the way the stock gauges did. If you plan to surface mount them like Levellord did, you should used the smaller 3-3/8" gauges. Some guys have gutted the factory gauges and used the outer shells to mount the SpeedHut gauges in the stock fashion. I chose to make a custom mounting plate with 3 holes for the SpeedHut gauges, the mounting plate will screw into the dash just like the stock gauges did. Here are some pics of my set-up:
I made this mounting plate from 16 gauge sheetmetal bought from Home Depot.
I clamped the sheetmetal between 2 pieces of 1/4" masonite to keep it from bending while cutting.
I used some rotary burrs like the ones used for porting cylinder heads to fine-tune the hole size and the shape of the plate until it fit into the dash.
The plate has notches and holes to fit the alignment tabs in the dash plastic.
I may need to grind a little off the bottom edge to clear the light housings above the wiper and heater controls.
The finished product (except missing the wood grain overlay).
Old Dec 30, 2019 | 05:19 PM
matt68F-85's Avatar
What are you using for a brake warning light ?
Thanks, Matt
Old Dec 30, 2019 | 05:43 PM
cdrod's Avatar
Rodney
The SpeedHut gauges have no provision for a brake warning light.
Old Dec 30, 2019 | 05:46 PM
matt68F-85's Avatar
I thought that might be the case. thanks.
Old Dec 30, 2019 | 08:15 PM
pettrix's Avatar
Brake warning light? Who needs a brake warning light?!?
You can always just wire in a dummy light somewhere if one is that forgetful.
Old Dec 30, 2019 | 08:49 PM
pettrix's Avatar
Originally Posted by cdrod
Pettrix:
How long did it take to do all that work?
Old Dec 31, 2019 | 01:03 PM
matt68F-85's Avatar
Maybe it’s just me but I prefer to know if I have an issue with stopping before I can’t stop.
Old Dec 31, 2019 | 03:32 PM
cdrod's Avatar
Rodney
Pettrix:
I worked on this project for a few days in the evenings after work: probably 10-12 hours. I first made a cardboard template out of a Cheerios cereal box to refine the fit, testing in the dash. I then overlaid the bezel in the dash with the cardboard template behind and traced the 3 holes, located the centers of those holes and using a compass I drew 3 circles slightly bigger than the SpeedHut gauge housings. I even mocked everything up, installing the gauges into the cardboard template to be certain everything would line up properly. Once I was satisfied of the template, I traced the template to the sheetmetal and began cutting and grinding, test fitting as I went along. Definitely a lot of work but I wanted the SpeedHut gauges to fit like the factory parts. I'm using an electronic speed sender in the 200-4r tranny and the SpeedHut gauges even have an electronic speedo output wire that I plan to feed to a Rostra cruise control system to make road trips more comfortable.
Rodney
Neil F85
Jun 16, 2019 08:48 AM
Hank
Dec 20, 2012 04:22 AM
trez
Mar 23, 2011 12:20 PM
Pinner
Apr 1, 2007 11:48 AM
