power window not working (hack) ?
Old Jun 18, 2019 | 06:43 AM
VikingBlue's Avatar
rear/side power window on 1971 442 quit working halfway up and is now stuck in that position....how to bring it back down without power ?
Old Jun 18, 2019 | 09:54 AM
No computer, so no hack.
Do all windows not work? Fuse.
Does it work with one switch and not the other? Switch.
Will the motor run with 12v battery power applied to it? Wiring.
Does the motor head turn but window does not move? Mechanism.
Will the motor take power but not move? Windings.
Check all that stuff. Lube the tracks and the joints. I think, if you take the motor off, the window will freefall to the bottom of the track. Ghetto fix, take motor out, drop window.
Old Jun 20, 2019 | 05:44 PM
FN723's Avatar
You need to open up the door where you can access the track. You may have a wheel that is worn out or it just might need some grease. You might also have something off the track which is binding. You can usually tell right off if there is something wrong. In any case if it's the motor you will have to get in there to replace it.
lemoldsnut
Feb 20, 2017 03:06 PM
pfergy600
Jan 29, 2015 06:37 PM
Delta88Royale
Jan 16, 2014 12:30 AM
5998DownUnder
Jun 19, 2013 07:29 PM
5998DownUnder
Jun 14, 2013 06:03 PM
