Rear window glass?
Old May 19, 2019 | 06:38 PM
Platinum69's Avatar
Rear window glass?
How much room is needed for the windlace on the inside of the rear window glass? Doesn't seem to be enough room after adhesive is on.
thanks
Old May 20, 2019 | 09:46 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Crystal ball says...ummm for a 1969 Cutlass/442/F85?
Enough room for the channel in the lace to fit into. You need to use the old school black sealer. The old school is ~1/2" think. The newer tends to be thinner which will throw off the fit of the windlace and the SS trim on the exterior.
Old May 20, 2019 | 01:19 PM
Platinum69's Avatar
Yes, 69 442. The black sealer you are referring to, is that butyl tape? Theres only about 3/8" of the pinch weld surface that the window overlaps when window is centered in the opening.
scrappie
Aug 13, 2019 10:00 AM
Keegan
Apr 2, 2014 06:47 PM
55newolds
Apr 27, 2013 02:42 PM
defiant1
17
Mar 6, 2013 01:56 PM
knighthawk
Jul 8, 2011 08:02 AM
