Help me please 😭 1965 425 olds
May 8, 2019 | 07:02 PM
1965Delta88okc
Sep 2018
I live in OKC I need to rebuild my Oldsmobile 425 engine I don't want nothing wild just reliable
1965Delta88okc
Find More Posts by 1965Delta88okc
May 8, 2019 | 07:23 PM
Vintage Chief
Jul 2018
Earth
Why do you need to rebuild your engine?
Vintage Chief
Find More Posts by Vintage Chief
May 8, 2019 | 07:36 PM
1965Delta88okc
Sep 2018
It lost power in started to tap bad on the topend
1965Delta88okc
May 8, 2019 | 07:39 PM
Vintage Chief
Jul 2018
Earth
Did you perform a compression check of each cylinder both dry & wet? What is the compression dry & wet of each cylinder?
Vintage Chief
May 9, 2019 | 08:43 AM
Onit
May 2018
Top end tap
Pull the valve covers. Look for broken spring, rocker, pushrod first.
Onit
Find More Posts by Onit
casting#386525 A
olds4life
10:06 AM
Help with early 425 identification
67cutlassguy
07:02 AM
1965 engine transplant
braden1351
01:06 PM
1965 425 flexplate.
Pewter442
04:56 PM
350 or 425 ??
bisscrac
Jun 6, 2012
10:34 AM
70 442 question
01:56 PM
