Rag joint rebuild, rubber disc
Old Apr 22, 2019 | 06:18 PM
jensenracing77's Avatar
Has anyone used one of these to rebuild their rag joint? I would assume it would be ok? I have never rebuilt one before but should be easy enough. Just wondering what the best rubber ring would be? Cut one from an old tire maybe, lol.
https://www.jegs.com/i/Ididit/535/30...RoCHrYQAvD_BwE
Old Apr 22, 2019 | 07:29 PM
66luvr's Avatar
I've put a few in, I usually bought a kit with new hardware because the ones I have worked on have rivets on 2 holes which I ground off the heads and knocked out. The kits come with bolts to replace the rivets.
I used to walk into any auto parts and buy the kit for around $10, I see some on ebay, like this one;
https://www.ebay.com/itm/1961-1981-C...ss!45638!US!-1
BTW, I have done a fair amount of business with this seller and have been well satisfied.
Good luck,
Old Apr 23, 2019 | 03:22 AM
Thanks, I may just go with that kit then.
Old Apr 23, 2019 | 04:33 AM
ELY442's Avatar
I have use these guys a couple of times from my local auto parts store.
http://www.finddormanhelp.com/Search?pcat=4&cat=38
Old Apr 23, 2019 | 08:36 AM
66luvr's Avatar
Well it looks like Auto Zone still has it. I looked there last night and came up empty but today it popped right up, and cheap! Like it used to be. $7.99 in stock at my local store, or so it says
https://www.autozone.com/suspension-...isc/730051_0_0
Old Apr 23, 2019 | 10:55 AM
I had no idea you could ever get these from the parts store. I will check with them
Old Apr 24, 2019 | 09:50 AM
Don R.'s Avatar
The kits are easy to find but can hard to install. Does your joint have splined connectors on both ends? My 63 Starfire only had one on the steering box end, had to remove the steering column to install.
Old Apr 24, 2019 | 10:48 AM
Lucky for me, I am pulling the car all the way apart. Yes, this one would be really bad to replace in the car.
Old Apr 24, 2019 | 12:29 PM
stetzie's Avatar
stetzie
Have you tried this company?
https://www.larescorp.com/product-ca...ings-couplers/
stetzie
Old Apr 24, 2019 | 12:42 PM
nicks1966's Avatar
I will preface that this was about 8 years ago but I was less than impressed with the dorman kit, and it didn't last long.
At the time my local advance auto parts stocked the Lares couplers, way better than the dorman kit.
I paid less than 20 for it then now part number 201 is 35.00.
theoldsrocket
Apr 10, 2013 05:52 AM
Indy_68_S
Mar 18, 2011 10:21 AM
808olds
Oct 7, 2010 10:05 AM
Wilson05
Suspension & Handling
17
Mar 24, 2009 09:01 AM
projectheaven
May 20, 2008 04:22 PM
