67 Cutlass radiator support
Old March 9th, 2019, 07:54 PM
edzolz's Avatar
Is the radiator support the same for a six or a V8 car? 67 F85.
edzolz is offline
Old March 9th, 2019, 07:59 PM
70Post's Avatar
I'll ask our buddy here when I go out to his place Monday or Tuesday.
70Post is offline
Old March 9th, 2019, 08:01 PM
edzolz's Avatar
Tell him I said Hi.
edzolz is offline
Old March 9th, 2019, 10:11 PM
Core support, upper radiator, or lower radiator?
Koda is offline
Old March 10th, 2019, 05:40 AM
edzolz's Avatar
What do you mean? I'm asking about the part that the radiator mounts to, the headlights mount to, other objects mount to, the fenders bolt to...
edzolz is offline
Old March 10th, 2019, 05:48 AM
Bfg
Bfg's Avatar
They should be the same but the only difference you might find are the mounting saddles at the base of the support to hold the radiator in place. They unbolt from the bottom.
Bfg is online now
Old March 10th, 2019, 09:35 AM
I mean there are three different pieces of metal you could be talking about.
The core support is the large 5 foot wide piece of metal that holds the headlights and fenders. The lower radiator support holds the bottom end of the radiator, and the top plate holds the top.
The top plate bolts to the core support, but the bottom plate actually bolts to the frame.
Now that you have clarified, no, there is no different to the core support, but, like BFG said, there may be a difference in the cradles on the lower radiator support.
Koda is offline
Old March 17th, 2019, 05:52 AM
edzolz's Avatar
Did you see H??
edzolz is offline
Old March 17th, 2019, 06:53 AM
Old School Olds
tru-blue 442's Avatar
Ed, PM me if you need Henry's #.
tru-blue 442 is offline
Koda
September 19th, 2013 07:02 PM
Doug in SD
June 13th, 2011 06:00 AM
ddx77
May 27th, 2010 04:53 AM
442C.D.
September 15th, 2009 09:44 AM
esisson
January 14th, 2007 04:38 PM
Quick Reply: 67 Cutlass radiator support
