Need help finding fuel sending unit on 1968 olds 98
Old February 5th, 2019, 07:50 PM
olds89's Avatar
olds89 is offline
Old February 5th, 2019, 08:04 PM
jaunty75's Avatar
You won't find one, at least not new, unless you get lucky on ebay, but then you'll pay a small fortune for it. My '67 Delta 88 uses the same sender, and when I needed a replacement, I found that a sender that fits early '70s Buicks and Oldsmobiles would work.
Specifically, you want Spectra Premium part number FG-106A, $50 at Rockauto and probably available through any auto parts store at who knows what price.
jaunty75 is online now
Old February 6th, 2019, 06:32 AM
drjimz's Avatar
I put one of those in my 69 98. Although it works, the needle floats.
drjimz is offline
Old February 6th, 2019, 07:01 AM
68442's Avatar
You Could also send yours out to get rebuilt
68442 is offline
Old February 6th, 2019, 02:17 PM
drjimz's Avatar
Who rebuilds them?
drjimz is offline
Old February 6th, 2019, 05:02 PM
jaunty75's Avatar
Yes, it does, because the tank is not baffled as the canister acted to dampen the fuel sloshing effect on the sender's float. But is the glass half full or half empty? The replacement sending unit still indicates how much gas is in the tank, and that's a heck of a lot better than no gas gauge at all.
Old February 6th, 2019, 05:16 PM
drjimz's Avatar
Half full! I’m fine as long as I know there is no true replacement
drjimz is offline
Old February 7th, 2019, 08:02 AM
That is the fuel sending unit I used in my 71 98. Here's a thread on when I installed it:
https://classicoldsmobile.com/forums...1971-98-a.html
The build quality of those sending units is pathetic. As I stated in the last post of the thread I linked, the fuel sending unit signal wire stud grounded against the body of the car with the tank installed. This caused my gas gauge to constantly read E. I was able to fix the problem by drilling out the stud and using a machine screw to attach the signal wire.
Olds64 is online now
Old February 7th, 2019, 03:51 PM
Lansing built
1970cs's Avatar
Who rebuilds them?
https://www.bobsspeedometer.com/1/120/services.asp
Pat
1970cs is offline
fast2pass
August 26th, 2020 11:40 AM
onofre442
July 22nd, 2015 07:51 PM
jackrhutton
June 17th, 2014 07:16 PM
hippy72
May 24th, 2014 12:51 AM
Pfiffle
February 21st, 2008 06:43 PM
Quick Reply: Need help finding fuel sending unit on 1968 olds 98
