T350 Auto Shifter
T350 Auto Shifter
What is the best recommendation for an aftermarket floor shifter for my 1964 F-85 Cutlass that has been changed to a T350??
The car is an original floor shift with the center console, so I would like something I can integrate with that.
Thanks,
Thirdcoast
Thanks,
Thirdcoast
Thanks Joe
As usual, you are The Source..
I am probably going to have to change the shifter lever as mine has been broken where it goes into the T-Handle.. Been trying to figure how to repair it, but think part is gone..
TC
TC
You can try adapting the G-body Cutlass shifter to the original console. It has a similar size and stick. These came in both three speed and four speed versions. G-body on the right.
I would suggest another possible choice, the B&M Quicksilver shifter is installed in my 67 CS with factory console. I guess it depends on your need for originality. You do lose the gear position indicator but I'm still looking to get mine to work.
Keep in mind that the OP has a 64 with the early console and round shifter stick.
Shifter
Joe, I think I did not give the correct info on my shifter. I am attaching a picture of my console & shifter.
1964 F85 Cutlass Driver Side Interior
It apparently has already been changed to the T Handle model in the picture. The problem I have which seems to be fairly common is the Shifter Lever top where it connects to the T Handle is broken.
I guess I need a new Shifter or a new Shift Lever or thanks to the link to Shiftworks, their adapter to a round ball..
I am open to any of these fixes, but for now will try to rethread the broken top of my existing shift lever, then if that works purchase the adapter form Shiftworks.
If that does not work, I will probably purchase an aftermarket shift lever if I can find one.
Thanks for all the help,
Thirdcoast
Thirdcoast
Thirdcoast
Thirdcoast
The top of the stick has a finicky arrangement and the pot metal tabs break very easily.
Once these little tabs break off, it is nearly impossible to repair (yeah, there have been people who machine off the top of the stick and fit a stainless steel extension instead). I suggested using the G-body shifter because they are readily available, already work with a three speed trans, and are close in shape and function to the original.
vista461
August 8th, 2009 12:16 PM
