Car veering to the left.
Old Nov 20, 2018 | 11:44 AM
Tiberian Fiend's Avatar
So the steering is sorted out on the '72 now, but now the car veers to the left while braking. I'm guessing it still has drum brakes, so is this a wheel cylinder problem, or something else?
Old Nov 20, 2018 | 11:48 AM
I'm thinking need more drum adjustment to the right in, maybe back the left out one. Also could be some air in the right side.
Go for a drive, grab a nice parking lot, hit 20, apply the parking brake smoothly, and see how it pulls. This will eliminate rear drums from consideration if no pull.
Old Nov 20, 2018 | 12:41 PM
shiftbyear's Avatar
It could be only the left brake is applying. A stuck wheel cylinder on the right can cause this. Jack up the right wheel and have someone step on the brakes. If you can spin the wheel, something is not causing the brake to apply. If the brake does apply it may be as Koda suggested, just and adjustment. Good luck
Old Nov 20, 2018 | 01:44 PM
RandyS's Avatar
You might also have a leaking brake cylinder on the R/F allowing brake fluid to get on the shoes. I don't think a problem with the rear brakes would have any effect on the car pulling to one side.
Old Nov 20, 2018 | 01:53 PM
68442's Avatar
Possible pull cause on drum front brakes
1) Wheel cylinder sticking
2) Shoe adjustment
3) Collapsed brake hose
for starters
Old Nov 20, 2018 | 02:51 PM
2) Shoe adjustment
for starters
Another possible cause is leaking fluid resulting in slippery shoes.
Old Nov 21, 2018 | 03:48 AM
Ozzie's Avatar
You have a lot of good suggestions. As indicated, it is likely in the front brakes. You'll never know without doing a brake inspection. My suggestion is that you do it before getting into trouble during a crisis circumstance.
Old Nov 21, 2018 | 07:01 AM
Actually leaking fluid causes a wheel to lock up. It can also be one of the rears, although the pulling would be less dramatic.
Don't speculate, pull all 4 wheels and perform an inspection. If any of the wheel cylinders are leaking and the brake shoes got soaked, repair or replace the wheel cylinder and replace the shoes (they come in 2 wheel sets).
Now would also be a great time to clean, inspect/ replace, repack both inner and outer front wheel bearings.
Old Nov 21, 2018 | 10:55 AM
That was not my experience. Prolly depends upon how slippery the shoes get.
Old Nov 21, 2018 | 09:00 PM
I just went ahead and replaced all of the wheel cylinders, hardware, and bearings on my '67, but if I was planning on keeping this car, I'd just go ahead and convert it to power disc brakes. I'm thinking of trying to find someone to trade it to once I get the engine rebuilt on my old daily driver or if the body shop ever gets around to fixing my '67 so I can actually drive it, though, so I don't want to put more work or money in than I need to to get the car drivable.
I drove the car some today, and the problem isn't nearly as bad as it was yesterday. I didn't experience any pull at all when I first started driving it, then I experienced it slightly intermittently, changing even from stoplight to stoplight. I will have to lift the car tomorrow or Friday to see which wheel isn't braking. I don't want to just yank the drums off to see which cylinder is leaking because it's a pain taking the wheel bearings off and putting them on again. I really hate having front drums.
Old Nov 24, 2018 | 12:24 PM
Well, I lifted the car, found out the right front wheel wasn't braking, took the drum off, and the wheel cylinder was bone dry. But I also discovered what I'm guessing was the real culprit in the process:
The master cylinder reservoir was also filled with water and rust, both chambers. I think I skimmed all of the water off of the top, but there's still a lot of rust in the system. Do I need to get it all out?
Old Nov 24, 2018 | 02:49 PM
The hose is a common issue when they get old, might as well do the opposite front hose also. I would suction out the fluid in the master, wipe the inside down, and refill with fresh. I start with farthest rear wheel cylinder (RR) and bleed until it flows clear while refilling the master cylinder as needed, then the LR. Move to the fronts, do the RF and then the LF.
matt69olds
Jul 16, 2018 03:26 PM
oldsguybry
Apr 12, 2017 05:53 AM
Phil Glass
Brakes/Hydraulic Systems
Sep 7, 2010 09:30 AM
henryk8398
Mar 15, 2010 04:04 PM
IDAS 69
Jun 10, 2009 02:36 AM
