For your viewing pleasure...
So I gave my stepson the keys to my Cutlass for the day to take some pics, and this is what he saw through his lens....enjoy!
Dave, as per my PM here is the image of the RH mirror. There is no RPO code I know of for these but they do a decent job matching the look and front profile of the Drivers mirror.
Hood Scoops
72445
The hood scoops that you mounted really sharpen the cars looks up. The stance , tires , rear spoiler , and hood scoops make the car present itself as a car to be reckoned with. A great looking car! I wish that more Olds folks would make the effort to wander off the beaten path a bit and make the Olds appearance eye catching.For the most part I have finished the mechanical work on my 68 and am now working to give the car the look that I want. The motor is a 455 bored and stroked to 500 cu in and is loaded with plenty of goodies that make it both stronger and more powerful than the original 455. I wanted a way to get cooler air to the motor and looked at several options. A body guy that had done some work for me suggested that I look at the hood scoop and air intake system on the 65 - 67 GTO's. As it turns out I really liked the look of the scoops and the simplicity of the air inlet. A 68 Cutlass hood was purchased as well as a reproduction 65 - 67 GTO hood. If things did not work out I did not want to ruin a pristine Cutlass hood. Also to be rounded up was the GTO air inlet system. This was all available in reproduction parts. Prior to measuring we mounted the GTO air inlet system on the Cutlass and got it situated where it needed to be in order to work properly with the hood closed above it. The Air filter base was a custom effort with part of my original assembly welded to the modified GTO base. With the air assembly mounted where we wanted it the measuring began.After alot of measuring and remeasuring the hood frame that supported the scoop and air inlet was cut out of the hood and grafted into the Olds hood. We were lucky to get a good Olds hood with no rust hidden between the hood skin and frame. The project is nearly done with the scoop mounted and the hood primered and ready for some Fire Red paint and a single black stripe. It will get finished off with a 1/4" black pinstripe surrounding the main stripe 1/4" away.
Given how many mods the car has had done I am also going to present it as a Cutlass SS. The interior is still stock 68 but pretty well everything else has had a healthy dose of attention. It was not built as a 442 clone but just as a vision that I had in my head! My SS badges are getting close to done with the fellow doing it refining his mold to make them cleaner and looking more OE like. I am sure that the purists won't like the off the beaten track look but I do not worry about it as the car belongs to me and I am free and able to do as I please to it - good or bad. To my American friends - Happy Thanksgiving!
Prior to Cosmetic surgery
GTO Air assembly
GTO air assembly side
Modified Olds Hood frame
Ready for sanding and prep
Primered with stripe laid out
Primered with stripe laid out rear view
Factory looking underside. Hard to tell it has been edited.
First Cut at my Cutlass SS badging
GTO Air assembly
Neat! That's a kool idea! I like the execution so far. It will be exciting when completed. Interesting take on the SS emblem. As I read the text, I was wondering what it would look like. I like the Olds styling.
...and a hood swap...
....and a recent pic..
Thread Hijack
Did not mean to offend. Wanted this in my original the " Cutlass Progress" thread but obviously did not get it there. Some of us Olds guys are a little not all that tech savy but are car nuts. Good thing that I am not a astronaut or commercial pilot. Just a car guy!
BOOWAH
August 23rd, 2017 06:19 PM
