1957 Olds front suspension help
Old Nov 5, 2018 | 07:33 AM
Nomadoc's Avatar
So I just finished installing the front suspension in my 57 and it appears that there is a significant amount of negative caster.
The manual calls for 0 to 3/4 degree of positive caster.
It seems to be more than can be adjusted out with shims.
It doesn't change with load.
I have replaced the ball joints and control shafts/ bushings. The control shafts are centered in the arms as recommended in the shop manual. The lower ball joints are on the correct sides. The upper ball joints are the same side to side as are the knuckles (as far as I can tell).
Any ideas?
Bill
Old Nov 5, 2018 | 04:31 PM
Your not going to get an accurate measurement until you have all the weight on the wheels. I wouldn't worry about it until the car is reassembled.
Old Nov 6, 2018 | 03:47 AM
Nomadoc's Avatar
Ok, thanks Eric.
My default mode with this car is to assume I have screwed something up until proven otherwise......
Bill
mpolds
May 3, 2020 11:08 PM
tgilligan
Suspension & Handling
Jun 13, 2019 04:51 AM
76olds
27
Feb 27, 2019 08:55 PM
1970Ragtop
Feb 7, 2017 06:35 PM
Fletch
Sep 18, 2011 09:10 AM
