special tranny
Old Oct 15, 2018 | 03:11 PM
vickycar's Avatar
special tranny
need someones take on this, i was talking to a guy today who has a 72-442. automatic with a transmission that was a cross between a 350 and 400. says they only made a limited production of them and they where for drag racing. he says the shift indicator read D S L and the S stands for stripe. his is blown and is looking for another. i never heard of such a tranny but i learn something everyday. what's the sites take on this
Old Oct 15, 2018 | 03:19 PM
cherokeepeople's Avatar
if anything it's a turbo 375.turbo 400 case 350 type guts,if i remember right the clutches have 1 less plate in em then a 400,and they have a smaller tailshaft
Old Oct 15, 2018 | 03:23 PM
don71's Avatar
same but different
I"m thinking he just had a two martini lunch. Hmm...
https://en.wikipedia.org/wiki/List_of_GM_transmissions
Old Oct 15, 2018 | 03:24 PM
don71's Avatar
same but different
I thought about the 375, but its a light duty 400 as far as parts are considered.
Old Oct 15, 2018 | 03:41 PM
Title of this thread is too funny......
Old Oct 15, 2018 | 04:28 PM
There is also the 375B, with is a heavy duty 350. Other than maybe valve body calibration the only “heavy duty” upgrade is the thinner direct clutch piston that allows for the installation of 5 clutch discs over the factory 4. Anyone with a lathe can duplicate the piston. I have done it on brake drum lathes, talk about low buck!!!
Old Oct 15, 2018 | 06:16 PM
They all say D S L . The S stands for Super.
Old Oct 15, 2018 | 08:23 PM
oldspackrat's Avatar
IF, & I say IF, he has a th375 transmission in his car it definitely did not come from the factory. The only automatic options available that year were th350 or th400. The only stripe must have been on the beer he was drinking.....
Old Oct 15, 2018 | 10:23 PM
DSL is an important feature on women too.
Old Oct 15, 2018 | 10:34 PM
Gerald Nickels's Avatar
DRIVE SECOND LOW That's what I'm going with. I know Super was in a 55 Olds 3 spd trans.
Old Oct 16, 2018 | 05:18 AM
There was a TH375, which was a TH400 case with light duty internal parts and the small (TH350 size) output shaft. This trans was only used behind the 350 motor in heavy cars, namely the Vista and the Delta 88. The TH375 only came in a long-tail version.
There was also a TH375B, which was a HD version of the TH350 and used the TH350 case.
Neither of these transmissions was ever used in a 442.
Old Oct 16, 2018 | 09:55 AM
VI Cutty's Avatar
I'm plum outta S for Strip transmissions but I've got a few R for Race ones left!
Old Oct 16, 2018 | 12:19 PM
deaditedelta's Avatar
You can rebuild your transmission, which is the way I would go. You can put in some nice performance parts like hardened hard parts and a shift kit. Its a glorified 350, I have the 375 in my delta. its a 350 with a long tail. Fatsco trans parts stocks a lot of the antique transmission parts.
Old Oct 16, 2018 | 01:32 PM
How about some P for passing ones?
Old Oct 16, 2018 | 02:02 PM
76olds's Avatar
Hookers under Hood
I think you know by now what the sites take is on this " Special Strip enhanced " transmission .
I have the L on my 76 , but.. I only use it to get home quick if I see lightening .
Eric
pops1958
Vista Cruiser & Wagons
Jun 24, 2019 12:39 PM
dnmfranco
Apr 24, 2014 07:24 AM
Pacecar
Jan 15, 2012 01:56 PM
archeryshooter
Jul 18, 2011 07:27 AM
turnpike_cruiser
Jun 26, 2010 05:47 AM
