Coolant Fitting...
Old Aug 6, 2018 | 08:59 AM
71OldsCut's Avatar
Coolant Fitting...
Hi,
I was going to add some transmission fluid and right by the dip stick I saw a tee fitting with a cap on it on one of the coolant lines going to the heater core. I moved it slightly and coolant started spraying out from it. What would this be for? The tubing doesn't seem to be in the best shape so I was just going to go buy a fresh piece and install it, I just wanted to know if this capped tee fitting is required or can I just run a new piece of tubing without it.
THanks!
Old Aug 6, 2018 | 09:22 AM
That is part of an aftermarket back flush kit. Hose goes there, water goes in, goes through block, and goes out uncapped radiator fill hole.
It's a procedure of dubious provenance, and has been known to cause heater core leaks and excessive mineral deposits from a whole lot of tap water.
You can certainly replace the entire chunk of heater hose without worry. Do the other one at the same time, replace clamps as needed, and have peace of mind.
Old Aug 6, 2018 | 09:27 AM
71OldsCut's Avatar
Sounds good. I will do that. Thanks
Old Aug 6, 2018 | 09:43 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Often when a standard flush is preformed the heater core doesn't get cleaned out as well as the radiator and engine block, thus it eventually fails. However this flush connection point helps as its close to the core. As you can see the plastic Tee isnt very robust. Flush the heater core (gently) by its self. I suggest you replace both heater core hoses. Before you remove the clamps at the core leave a foot of hose on one side. Then using a low pressure garden hose flush the core. Ill bet a ton of brown comes out of it. Follow the water with either a shop vac or low psi compressed air to remove the tap water. You have to be gentile with the core as its kind of fragile and can be compromised easily if you put too much pressure at it...water or air.
Hook up the new hoses and refill the system. Never use tap water to cut straight coolant. Use the premixed coolant or use distilled water to cut straight coolant. Of course MAW (might as well) do the rest of the cooling system if it hasn't been serviced in a while...including a new high quality 190*F T Stat. Name of the game when flushing is to get a complete flush, evacuate all tap water and chemical flush, refill with fresh coolant.
Old Aug 6, 2018 | 09:52 AM
The procedure actually worked/works very well and is still available today.
Old Aug 6, 2018 | 03:19 PM
dc2x4drvr's Avatar
Be careful removing the hoses from the heater core, the pipes are brass, I would cut, or slit the hose to make removal easy.
Old Aug 6, 2018 | 04:15 PM
How about starting with draining a bit of coolant from the radiator. That's what the petcock is for. Minimize the amount of coolant you'll spill. If you do get some on the ground be sure to flush it with plenty of water as pets are attracted to the sweet smell of antifreeze and can get violently sick.
OP - you can replace this with OEM looking hoses, or ones from O'Reily's or Autozone. In the meantime unless that fitting is leaking it's perfectly fine to leave it alone because it's not hurting anything.
Old Jun 23, 2020 | 05:53 AM
Sugar Bear's Avatar
Haven't tried this but...make an adapter to attach the garden hose to both of the block drain plugs at the bottom of the block by the motor mounts. Also leave those plugs out for a few minutes when flushing from the top.
Good luck!!?
Mustfire
Aug 29, 2017 02:49 PM
Armando S Nortez
Nov 15, 2013 08:43 PM
Armando S Nortez
Aug 23, 2013 04:37 PM
70Cutlass_408
Jul 30, 2011 02:50 PM
ztim
Dec 13, 2007 05:07 AM
