Oil change
Old Jul 14, 2018 | 04:48 PM
My2nd 69 442's Avatar
Oil change
l知 about ready for my semi-annual oil change and l知 considering using synthetic oil.
What are your opinions on going from Dino oil to synthetic oil?
My car is a stock 69 442 with 59,000 original miles
Old Jul 14, 2018 | 06:05 PM
You still need ZDDP in the oil, even if it's synthetic. Royal Purple has a version that has this, as well as Brad Penn. These are the two that come to mind.
Old Jul 14, 2018 | 06:24 PM
Sugar Bear's Avatar
I wouldn't particularly if you have an original non-leaking rope type rear main seal. Stay with a premium dino oil.
Will this start a debate about synthetic and leaks???
Old Jul 14, 2018 | 06:39 PM
Generating leaks is my major concern. In addition to my 442, l also have a 67 Camaro ragtop. I went to synthetic oil and generated many leaks. I would fix one and another would pop up. I ended up pulling the engine, resealed completely, serviced with Dino oil a d all is good for 4 years now.
I will probably stick with Dino oil in the 442
Old Jul 14, 2018 | 06:54 PM
Sounds like you answered your own question. Use a quality oil with a friction package meant for flat tappet cams.
Old Jul 14, 2018 | 08:57 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Valvoline Racing Oil is another one that has ZDDP in it. I use it in my 54.
Old Jul 14, 2018 | 09:24 PM
Charlie Jones's Avatar
Phantom Phixer
Everything you always wanted to know about motor oil .
(And even more ! )
https://540ratblog.wordpress.com/201...-test-ranking/
MudEye
Apr 22, 2021 06:44 PM
scooter123
Mar 5, 2014 11:23 AM
jpc647
May 4, 2013 10:58 AM
Tony72Cutlass'S'
Sep 23, 2012 05:44 AM
