Correct carb for 65 Cutlass with 330
My 65 Cutlass F85 Holiday Coupe with a 330 and Jetaway came to me with a Carter carburator (forget the number, but it cross-references to an early sixties Corvette with a 327 engine).
It starts and runs fine, but I'd like to make an effort to find a carb that it would have had from the factory. For some reason that information seems to be hard to come by. Anyone have that information?
Thanks!
Thanks!
Thanks everyone, very helpful as usual.
How does the 4GC compare to a Q Jet from the 66 or 67 models? Originality aside, would there be any benefit to using a later carb on my 65?
Good question. It has to do with my unfamiliarity with the Rochester carbs. Yes, I'd like the "correct" carb on the engine (seeing that most everything else on the car is original). However, I wouldn't want to go through the effort of sourcing one and then finding out that I should have gone with a later Q Jet because perhaps the 4 Jet is problematic in one area or the other, I don't know.
If the 4 Jet is an all-around good carb that's easy to live with on the street, I'll try to find one, but would be good to get that confirmation first.
Thanks for the tip on avoiding a 66 carb and the reminder on the mounting pattern, appreciate it.
