Look what found
Old May 6, 2018 | 02:19 PM
marxjunk's Avatar
Look what I found
Old May 6, 2018 | 02:22 PM
marxjunk's Avatar
Old May 6, 2018 | 03:11 PM
BackInTheGame's Avatar
Nice!
Schweet! Do have a plan in mind to put this into use?
Old May 6, 2018 | 05:17 PM
marxjunk's Avatar
no..i just couldnt pass it up..i dunno what the heck to do with it...
Old May 6, 2018 | 06:08 PM
lshlsh2's Avatar
71 cutlass convertible
Put a piece of glass on the top for a neat table.
Old May 6, 2018 | 07:33 PM
zeeke's Avatar
Get 2 big a$$ hog-lly carbs and put it on a 455. If you don't drown the motor with fuel maybe you can hit 88 MPH and travel back in time... Helloooooo McFliiiiiy...
Old May 7, 2018 | 05:01 AM
RetroRanger's Avatar
72 Olds CS
Is it black from being painted?....or cooked over an open fire?
Old May 7, 2018 | 10:40 AM
marxjunk's Avatar
Powder coating
Old May 7, 2018 | 10:56 AM
CRUZN 66's Avatar
Olds Fever
I have one of those NOS still in the box which I purchased years ago for my 66 442 and then decided not to use it since I preferred the Tri-Power setup...
Old May 7, 2018 | 02:46 PM
How does one run them? Two four barrel Holleys I assume. Are they set to run in parallel, like the front carb copies the back carb, or do you go on the front two barrels then dump 6 in when you hammer it?
Old May 8, 2018 | 05:27 AM
marxjunk's Avatar
I ran a few back in the eighties and nineties on small block Chevys
I ran the smallest Holley 4-barrel I could, the the front carb was the primary and had it hooked on a progressive type linkage and the rear was a secondary wasn't bad didn't have enough gear though so you had the feather into it... But it was a blast I can't remember a car that I had as much fun as one of those things hanging out the hood....
This thing is freaking huge I'm really amazed at how big it actually is and heavy holy crap it takes two people to pick it up... I had to carry that thing through the swap meet and of course it was as far as away from the truck as it could be... suuuucked
Old May 8, 2018 | 07:35 AM
Tedd Thompson's Avatar
Looks like a rat rod toy to me. That thing would draw a crowd at a car show stuffed in to a thirty something pickup with a exposed engine..... Tedd
Sep 19, 2016 12:20 PM
scooter123
Apr 7, 2012 09:03 AM
jensenracing77
Dec 12, 2011 12:21 PM
sx455raidercelticfan
Jun 20, 2010 09:08 AM
MN71W30
May 2, 2009 03:01 PM
