aluminum heads for my 67 330 engine?
Old Sep 16, 2017 | 04:47 PM
MudEye's Avatar
Was thinking of replacing heads with a lighter option....have the 330 high compression. Have a valve going bad and may pull the heads....Your opinion please..Would these provide as much performance or better? Than my 330 heads?......Thanks....http://www.ebay.com/itm/Oldsmobile-A...1ZVtoe&vxp=mtr
Old Sep 16, 2017 | 05:45 PM
lemoldsnut's Avatar
The stock heads you have are very good heads just have them rebuilt.
Old Sep 16, 2017 | 05:56 PM
Those are BBO heads. To use them on an SBO like your 330, you need to mill them quite a bit to reduce the size of the chambers. You need to replace your mechanical fuel pump with an electric one because they won't clear the pump. You need to use a Performer RPM and have it port matched to the larger BBO ports. There is a LOT of "collateral damage". As noted, have your original heads redone.
Old Sep 16, 2017 | 06:53 PM
MudEye's Avatar
10-4
Am I falling into the Aluminum head hype? Or are they ( Aluminum heads ) an advantage ( besides the weight ) I hear that they take longer to warm up in the winter ( almost here ) But do they produce anymore horsepower for the the swap?......Weight loss vs hp performance?
olds 307 and 403's Avatar
Out of Line, Everytime😉
http://www.ebay.ca/itm/64CC-403-OLDS...gAAOSw8cNUMLDX
You need a pair with the 64cc chamber like above. Avoid Mondello Performance, if at all possible.
Old Sep 16, 2017 | 06:59 PM
MudEye's Avatar
Will these work with my 330 high compression engine heads?.....
Old Sep 17, 2017 | 04:19 AM
Nearly every vehicle on the road today has aluminum heads, so whoever told you this is full of it.
Old Sep 17, 2017 | 07:41 AM
MudEye's Avatar
I think I'm going to take your advice on this one and have them redone.
Quite frequently now when i start the car ( after a little cruise ) I get a backfire and black smoke puffs out of one exhaust.....Valve spring job? vs heads redone?
Old Sep 17, 2017 | 08:02 PM
You want new 2"/1.625" valves with the bowls opened with a cutter, milled for straightness, multi angle valve job, new springs, guides and seals. You can upgrade to positive seals at this time. That is what you want done.
Old Sep 18, 2017 | 07:34 AM
MudEye's Avatar
Then will I be able to use gas without adding lead? ( after new valve job )
Old Sep 21, 2017 | 03:57 PM
classicmuscle442's Avatar
Yes, really did not need to anyway.
Old Sep 21, 2017 | 09:47 PM
Get stainless valves if you are worried about valve recession. or just add 4oz.of Marvel Mystery Oil to every tank of gas.
tocicar8825
Sep 21, 2021 07:10 AM
The_Jeremiah
Feb 7, 2017 07:11 PM
drjr56
Nov 13, 2012 02:59 PM
real57vetteguy
Nov 8, 2011 07:32 AM
Nor Cal Andy
Aug 22, 2011 07:17 PM
