dual gate shifter
Old Sep 8, 2017 | 09:11 AM
71cutlassdroptop's Avatar
dual gate shifter
Can anyone help with the year of the dual gate shifter. Going to look at it tonight. The seller said all of the spots are water. Can't tell if if it has any major pitting until I look at it. Any help would be appreciated
Old Sep 8, 2017 | 11:43 AM
svnt442's Avatar
Judging from the wood grain I'd say 71 or 72.
If there is a neutral safety switch on the rear bracket it would be a 70, but I doubt that.
Old Sep 8, 2017 | 12:21 PM
Good eyes. To clarify, this shifter fits all 1970-72 consoles. The woodgrain applique is different from year-to-year, and the 1970 versions incorporated the NSS; later years simply used the column-mounted NSS operated through the backdrive linkage.
Old Sep 8, 2017 | 04:37 PM
w-30dreamin's Avatar
71 & 72,now I want a 68
As long as the lighting is correct in this pic,that is a 71 wood grain.
How much is he asking?
Old Sep 8, 2017 | 06:10 PM
it's a 71 or 72. No NSS on it. Gave $100.00 it has the rear bracket, Think it will be a nice driver quality shifter. Everything seems to work. Will probably need a top plate once I get it cleaned up. not sure if I want to dip in a rust removal or media blast the shifter has a bunch of surface rust, hopefully not a lot of pitting. Needs a ****
Old Sep 8, 2017 | 06:28 PM
RetroRanger's Avatar
72 Olds CS
I picked up a generic black round **** for $~4 from rock auto for mine, **** is probably the same one the repops houses sell for ~$29
Old Sep 8, 2017 | 10:17 PM
4speed455's Avatar
Check H&H Classics. They sell the best quality wood grain, with metal back like the original for the top plate and console. Much nicer then the sticker on The Parts Place top plate. http://www.hhclassicauto.com/products.html
Old Sep 12, 2017 | 05:54 PM
Looking at cable options on e-bay and OPGI. The one from OPGI said 30 1/2" long prior to adding to cart. Once added to cart it changed to 29 3/4" long. Looks like INLINE Tube has the same cable 29 3/4" long for less. Everything on e-bay has the same GM part # 406266. Any suggestions?As alway Thanks in advance.
Old Sep 12, 2017 | 06:11 PM
4speed455's Avatar
I bought mine from Inline Tube. I didn't measure it but it fit and works correctly.
Old Sep 12, 2017 | 06:34 PM
Thanks 4speed455.
Old Sep 17, 2017 | 06:15 AM
Does the dual gate have a gear indicator slider like the regular automatic shifter to let yo know what gear it is in? Or does it just line up with the letters on the left? Still taking shifter apart and had this question. Thanks
Old Sep 17, 2017 | 06:18 AM
Neither the dual gate nor the same year factory shifter have a slider to indicate gear. The gear indicator lens is just illuminated with a single bulb.
Old Sep 17, 2017 | 09:11 AM
Thanks, wasn't sure if I would be looking for more parts or not.
Old Sep 17, 2017 | 09:33 AM
picture after it is was cleaned up and a coat of paint
RS3SDL2MG
Hurst/Olds
Oct 7, 2009 05:42 PM
1968 42
Apr 24, 2008 02:35 PM
1968 42
Apr 3, 2008 05:15 PM
