1975 Olds 98 Windshield Wiper Switch
Old Jul 25, 2017 | 07:29 PM
Canelo1's Avatar
i need to replace my windshield wiper switch. I have the part to replace it, but can I remove the ***** on the headlights, tempature, fan, and just take off the face plate? Or do I need to go underneath the dash?
Old Jul 26, 2017 | 06:14 AM
The headlight **** is the most difficult. The rest just pull off with some force. They are simply pressed on.
The headlight switch has a release button that is behind the dash, you yes you have to get back there. You need to pull the **** out to the headlight on position, then hold the button down and pull the **** the rest of the way out.
Old Jul 26, 2017 | 10:19 AM
Canelo1's Avatar
Thank you you very much for your help!
Old Jul 26, 2017 | 10:24 AM
Canelo1's Avatar
And the face plate should just come out too when all the ***** are off?
Old Jul 26, 2017 | 01:24 PM
You'll also have to remove the fan, AC, and lights and wiper ***** first. IIRC they pull straight off. The dash plate should be held by press in spring clips. I'd suggest rotate the AC vent to give a bit of pulling area to pry out the faceplate.
gwunta
Jun 22, 2024 08:59 AM
Olds442redberet
Jan 19, 2017 06:11 PM
tschie
Feb 14, 2016 09:45 AM
jwr7042
Jul 7, 2015 03:54 PM
brandon reynolds
Dec 18, 2013 03:05 PM
