393800 CFD8 DR Huh?
Old Jul 25, 2017 | 06:21 PM
jimbr70's Avatar
393800 CFD8 DR Huh?
I know I saw info on this but I have searched -- no luck. Read Diff info needed. 1970 Delta 88 / 455 2BL, Auto
Right side of center on yoke: 393800
Center of yoke: CFD 8
Left of center: DR
No markings to be found on tubes - and I scrubbed them... but just how small are the codes if on the tubes? Don't see'em.
Goal - what is it, and what will it cost to be anti-slip?
Old Jul 25, 2017 | 06:55 PM
2blu442's Avatar
Does it have 11" brakes? Joe would know for sure, but if it has the 11" brakes I think its likely a 9.3" rear end. Posi units are out there, but they're not very common. John
Old Jul 25, 2017 | 07:58 PM
jimbr70's Avatar
Big drums - every bit of 11" - not sure what other size they had - anything over 11 - i'd have to measure more carefully.
Old Jul 25, 2017 | 09:38 PM
I think CFD is for Central Foundry Division. This is on just about every cast iron part.
As for the axle ID codes, they can be difficult to see due to being lightly stamped and rust, dirt, grease, etc on the tube.
Here's some shots of the codes on a couple of my O-Types:
Old Jul 26, 2017 | 06:08 AM
Yup. Twelve bolt cover, twelve bolt 9.3" ring gear. That's the big car Type O. Parts are non-existent. These were only used in the Olds full size cars.
Old Jul 26, 2017 | 04:48 PM
jimbr70's Avatar
Thanks for the pics Fun71. I'll have to go look again for codes.... Rrrrrr.
Old Jul 27, 2017 | 08:51 PM
2blu442's Avatar
Jim, did you see this post?
https://classicoldsmobile.com/forums...r-axle-id.html
70sdream
May 9, 2016 04:16 PM
cutlassefi
May 12, 2011 08:52 AM
coldwar
Feb 2, 2010 07:06 AM
Oldsguy
Dec 25, 2009 01:00 PM
Oldsguy
Oct 3, 2008 05:07 PM
