Engine start up
Old May 21, 2017 | 06:57 AM
Bfg's Avatar
Bfg
Engine start up
Getting ready to start rebuilt engine. Is it recommended to put coolant in it or can I just get buy with water initially. If any leaks I won't be wasting coolant.
Old May 21, 2017 | 06:59 AM
Water is fine, make sure your hoses are tight.
Old May 21, 2017 | 07:29 AM
Sugar Bear's Avatar
X2. If no leaks, change it out within a day or two as coolant is also a corrosion inhibitor.
Old May 21, 2017 | 08:40 AM
x3. Never do a first start with antifreeze - if there's a hellacious leak that you missed, it will be all over, and you'll be much happier if it's just water.
Put antifreeze in after you've proved that the system holds pressure without leaking.
Old May 21, 2017 | 09:16 AM
Bfg's Avatar
Bfg
Ok will do, thanks for the replys you guys!
brettb
Jul 17, 2013 04:47 PM
colemane
Apr 13, 2013 01:19 PM
Destructor
Oct 22, 2010 05:35 PM
rrielley
Sep 1, 2008 03:00 AM
D Appeldorn
Apr 24, 2007 12:52 PM
