value 1969 w30 block
Old Dec 4, 2016 | 01:08 PM
paul879's Avatar
69-72 olds owner
I have found a big block from a w3o cutlass needs to be rebuild has the right heads from factory any body have a idea what it is worth before i make the guy an offer thanks
Old Dec 4, 2016 | 01:29 PM
2blu442's Avatar
The block should be a G block 400. The heads should be D castings. If the carburetor, distributor, alternator and starter are available get them. The block itself is no different than the one used in the 442 and Vista Cruiser. But the heads if good are likely $3,000+, the bolt on parts I mentioned if codes are correct can add several hundred more, if all are correct possibly over a thousand more.
If you get it post pictures for us and we'll tell you more about it.
John
Old Dec 4, 2016 | 01:54 PM
paul879's Avatar
69-72 olds owner
thsnk you for the reply blue when i find out more ill let u know
Old Dec 4, 2016 | 02:07 PM
oldsmobiledave's Avatar
Fyi
The D heads are worth $2000-$5000 depending on condition.
The block is worth thousands.....but only to the owner of the original VIN matching car.
To everyone else the block is a boat anchor.
Old Dec 4, 2016 | 04:22 PM
83hurstguy's Avatar
Prob a bit high on the head value. I believe an NOS pair was available for less than $4k recently and didn't have a line waiting for them. I sold a really rough set (cleaned and passed pressure test) for $1500, and bought a beautiful, perfect low mileage set for $3200... So that's probably a better range.
Old Dec 4, 2016 | 11:00 PM
orange442's Avatar
Set of bare D heads just sold on Ebay for $6400 plus shipping!
Old Dec 5, 2016 | 07:01 PM
Stefano's Avatar
W-30 Carb and distributor can be much more valuable than stated.
Heads depends on a lot , it can cost $1,500.00+/-to properly go through a set of heads.....new, valves, seats, guides, etc.
Old Dec 6, 2016 | 07:41 AM
83hurstguy's Avatar
Holy crap. That's either gotta be shill bid, or a few people were hitting the sauce way too hard when the auction ended. Time to see if someone actually pays. There will be five more sets listed on eBay within days...
Old Dec 6, 2016 | 07:47 AM
D heads
Are you holding 5 sets of D heads?
Old Dec 6, 2016 | 07:51 AM
83hurstguy's Avatar
No... but you'd be amazed how many are out there on shelves available, but not advertised. When I posted a wanted ad for a set here and ROP, I had 7-8 pairs offered to me within 3 weeks. I thought a nice set was going to be hard to find. Now H heads on the other hand...
Old Dec 6, 2016 | 05:17 PM
classicmuscle442's Avatar
maybee post block stamp numbers? Just a thought, have a 70 without original engine block
bspaulding
Sep 3, 2016 04:15 PM
Nickyloves442s
Jul 7, 2015 12:19 PM
rollerball
Apr 27, 2014 11:55 AM
72xw30
Dec 1, 2013 03:58 PM
Napoleon Solo
Apr 24, 2013 11:02 AM
