Power antenna repair
Old September 5th, 2016, 02:43 PM
Gmcdually's Avatar
I have finally decide to repair my power antenna on my 1979 HO , I have the part and have read the manual. Is this job as difficult as it looks or does anyone have any tips.
Gmcdually is offline
Old September 8th, 2016, 08:23 AM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Since nobody has responded Ill take a shot. Some general advice here...Once installed keep the telescoping sections lubed with WD40 every so often. Make sure you have the ground connection and radio lead clean and tight. If a tool is required to remove the escutcheon on the fender get it or you will damage it. Might consider pulling the wheel well out and or the fender for ease of access. If you do so mark it well so it goes back together in the same place. If you do remove body panels, apply painters masking tape to the body panel gaps to avoid scratching when removing and installing said panels(hood, header, door, fender etc...) Not a bad idea to tape the escutcheon area too.
droldsmorland is offline
Old September 8th, 2016, 05:02 PM
Gmcdually's Avatar
Thanks for reply. So it seems i have to remove alot of items to gain access to replace part. I was afraid of this. I will start this weekend and let you know how it goes. Fingers crossed, I do not do more damage.
Old September 9th, 2016, 05:56 AM
You shouldn't have to remove any body panels. If it's in the back you just remove the paneling in the trunk to access it. If it's in the front just lift the car, remove the wheel, remove the inner fender well and there it is.
BTW, sorry you have to drive that GMC truck. I'm sure you could find a good deal on a Powerstroke if you look hard enough.
Olds64 is offline
Old September 9th, 2016, 08:41 AM
If the car is nice and you dont want to take off paint...put electrical tape in the sockets to cushion the bolt heads. Milk jug plastic between open-ends can be successful too, if the fender needs to come off. Id certainly try wheel well removal approach first as we've suggested. Google it and get a manual for the car. This could be covered in an assembly manual. There could be a straight forward procedure for R&R of the antenna.
A 79 HO should have a front passenger antenna.
Old September 11th, 2016, 07:23 PM
cjsdad's Avatar
I wrote this for an '84 Toronado, should be similar.
https://classicoldsmobile.com/forums...r-antenna.html
cjsdad is offline
curtis mayfield
February 21st, 2023 07:13 AM
Southbayolds
November 10th, 2014 01:58 AM
perro
September 4th, 2007 11:52 PM
awspeich
November 5th, 2006 04:33 PM
JoshF85
May 25th, 2005 08:14 PM
Quick Reply: Power antenna repair
