350 block
Old Jul 13, 2016 | 03:46 PM
nisszx's Avatar
350 block
Hi can any one please tell me what this engine I bought came from
engine #30z114431
Cheers
Bill
Old Jul 13, 2016 | 03:49 PM
An Oldsmobile built in 1970 at the Fremont, California plant. 114431 is the assembly sequence number and doesn't decode to a particular type of vehicle. That would need to be surmised by knowing which vehicles were manufactured at the Fremont plant during that time frame.
Old Jul 14, 2016 | 08:06 AM
engine #30z114431
Cheers
Bill
That is a VIN derivative stamp, so it won't really tell you anything about the engine other than that it is from a 1970 Cutlass. The block and head casting numbers are more informative.
Old Jul 15, 2016 | 02:42 AM
nisszx's Avatar
350
Hi Joe the numbers I have found on the block tell me it is a 350 the numbers on the head are 8 is on the front cylinder left hand side 10 411 928 x 261 the strange thing is the valve size are inlet 1.875 dia .341 stem 4.465 over all length and the exhaust 1.625 dia same stem and 4.645 length hope you can make some sense out of that
Cheers
Bill
Old Jul 16, 2016 | 01:25 AM
nisszx's Avatar
350
Hi Joe the other thing which seamed strange was that the block and heads are blue which looks original
cheers
Bill
Old Jul 16, 2016 | 06:32 AM
cheers
Bill
Bill,
Your block and head castings weren't even born in the same year, so clearly the motor has been apart at least once. Blue paint is not original on that block.
bocoogto
Aug 26, 2023 06:09 PM
import extermination
Nov 27, 2011 08:25 PM
olds4life
Feb 9, 2010 08:48 AM
davepnola
Dec 18, 2009 05:50 AM
NEWOLDSMAN
Nov 17, 2009 12:19 PM
