now i'm looking at something i never seen before.
Old Jun 21, 2016 | 07:10 PM
dal442's Avatar
engine builders....
i developed a head gasket leak on my 455. i have tore it down and i am looking at the top of the pistons. looks as if i have accumulated carbon on the top of the pistons.....( stock flat...that i installed 14 years ago with the first rebuild ) here is the question....can i just scrap the carbon....or --- if i use carb cleaner with scraping will i possibly do any harm ? seems the left bank developed a leak just at the back corner....right at the last exhaust manifold bolt..... need just a bit of advise whether i can do any harm to the pistons if i clean them & if using any spray cleaning materials will do any harm ?
i would assume that somebody has some insight....
dal442
Old Jun 21, 2016 | 07:31 PM
Depending on how much carbon, soaking with brakeclean, carb cleaner, acetone, mineral spirits, etc... and a shop rag usually works well.
Old Jun 21, 2016 | 09:51 PM
don71's Avatar
same but different
That carbon build up is normal.
I see nothing wrong with scraping it off. A sharp gasket scraper or razor blade and some solvent...just enough to do the job.
Don't use scotch brite or sandpaper...ever.
It doesn't have to be dinner plate clean. Just get the largest build areas off.
Old Jun 22, 2016 | 05:10 AM
SeaFoam will soften and dissolve most of it - pour or spray it to soak, then leave it for a day or two and scrape with a soft scraper.
It'll all come off.
Old Jun 22, 2016 | 07:44 AM
If you are pulling the pistons out of the block, oven cleaner is the inexpensive trick for removing the carbon.
Old Jun 22, 2016 | 08:09 AM
I can see why you wouldn't want to use sandpaper (the grit could come off and fall into the engine). However, I don't see any problem using a scotch brite pad. Here's a video with good advice, it's not Oldsmobile but worth watching.
Old Jun 22, 2016 | 08:48 AM
I've used fine ScotchBrite along with SeaFoam and a brass wire brush, and it's worked great.
pjmia96
Jun 1, 2016 07:05 AM
swampjuice117
May 23, 2015 01:32 PM
oldspackrat
Dec 31, 2014 08:26 AM
PSOldsguy
Ninety-Eight
Jul 5, 2012 04:52 AM
gearheads78
Feb 24, 2012 03:02 AM
