Block id
Old May 31, 2016 | 08:01 AM
sammy's Avatar
Sammy70 455 Supreme
Block id
Never seen this casting before....396021Fa....GST?...and for your viewing pleasure it is upside down....again
File Type: jpeg
Old May 31, 2016 | 09:00 AM
Ted, it's from the late 72 - 76 model years. There were F blocks that had overlap dates (68-74). Does that help? BTW, where did you get it?
Edit: Not GST. It looks more like 08 T. T is an engine code used with the 455. I'd guess that 08 is either the mold number, or the production month.
Old May 31, 2016 | 09:15 AM
sammy's Avatar
Sammy70 455 Supreme
Thanks Allan.....I must have GST on the brain��...the seller thru it in with the 71 4 speed deal....want it?
Old May 31, 2016 | 09:18 AM
sammy's Avatar
Sammy70 455 Supreme
What is an overlap date?
Old May 31, 2016 | 09:46 AM
Sure, but it would cost a fortune to ship here. BTW, GST didn't arrive as a gift from the Gubment till Jan 1, 91 so anyone who thought of GST that far back must have also won countless lotteries
The G was produced from 68-74. GA from 72-76. The overlap of G/GA production was 72-74.
Old May 31, 2016 | 10:09 AM
Just an afterthought Ted,
Look at the heads on that 455. If they're GA, it's a 72. If they're J then it's 73-76. Also look to see if it has an EGR application on the drivers side of the intake manifold. That appeared in 1973 also.
Old May 31, 2016 | 10:26 AM
The VIN derivative stamp on the block will tell you the year of the block. Everything else bolts on and can be changed over the last half-century.
Old May 31, 2016 | 10:54 AM
Well...YEAH! That's what I meant..... But if he wanted to know whether the intake and heads were 72 or later.....my way works too.
bocoogto
Aug 26, 2023 06:09 PM
antweave
Apr 22, 2011 11:32 PM
olds4life
Feb 9, 2010 08:48 AM
davepnola
Dec 18, 2009 05:50 AM
NEWOLDSMAN
Nov 17, 2009 12:19 PM
