65 442 brake light problems
Old May 15, 2016 | 05:09 PM
jimmers1's Avatar
Turn signals work but only left brake light works.I think its in the steering column any help would be appreciated.
Old May 15, 2016 | 06:30 PM
Sounds like it.
Does your car have aftermarket 4-way flashers?
Do the taillights and front signal lights work normally?
Old May 16, 2016 | 03:12 AM
jimmers1's Avatar
brake light issues
There is no four ways and all the lights seem to work normal.I ordered a manual that should help.I never have known how they isolate the turns from the brakes without having feed back. Thanks for the reply.I will keep you posted Jim
Old May 16, 2016 | 04:09 AM
Signal light switch in thc column, then.
There's always a chance you can clean it up and get it working, but the complete assembly may be a bit hard to find new.
NAPA does have a "repair kit," though, consisting of a single part, which may be what you need.
Old May 16, 2016 | 05:43 AM
m371961's Avatar
I agree. The switch isolates the brake from the turn. With brake pressed volts go through the turn switch. When switch is centered, both brake lights are lit. When switch is on right turn, brake volts go to left light and vice/versa.
chasman414
Jun 25, 2020 07:05 AM
yeahbuddy
Brakes/Hydraulic Systems
Jan 15, 2014 02:10 PM
5998DownUnder
Ninety-Eight
Apr 19, 2013 05:56 PM
Del70
Aug 2, 2011 04:40 PM
Phil Glass
Sep 7, 2010 09:30 AM
