A/C cars
The OP has a 1970 model, so I assume he's asking about that particular model year. Pretty much all BBO cars with A/C got fuel return. All high perf cars also got fuel return. SBO cars (other than W-31s), not so much.
I wonder about the specs of the fuel pumps in terms of volumetric flow and pressure and if the return-line-plumbed pumps were stronger. As I recall, the Rochester carbs could only take 7 psi at the needle before overwhelming the valve.
The 1970 CSM shows 5-6 PSI (or 5-1/2 to 6-1/2 PSI) for the V-8 and 4-5 PSI for the L6. The reference to the return line says that it must be plugged when checking pressure. It also says that the pumps for the cars without the return line have an internal bleed valve. While there is no volume specification, there is a 15 in. (min.) vacuum specification for the suction side of the pump.
jensenracing77
Oct 25, 2009 05:22 PM
