Front air dam on a '69
Old Mar 27, 2016 | 06:52 PM
huskerala's Avatar
Happy Easter to all!
My '69 likes to run warm in the summer and I've thought of running a front air dam under the radiator to see if it would help. I know that it didn't have one from the factory. Thinking of installing an air dam from a G body Cutlass. Has anyone else out there tried this?
Currently my car does not have a shroud on it but will be getting one soon.
Old Mar 27, 2016 | 07:08 PM
tru-blue 442's Avatar
Old School Olds
I'm sure the the shroud will help quite a bit. Why not use the air dam
that goes with the a body? I have one of the air dams if needed.
Old Mar 27, 2016 | 07:13 PM
huskerala's Avatar
A body air dam
Thanks Tru Blue...can you post a photo of the A body air dam you have? I guess I've never seen one.
Old Mar 27, 2016 | 07:19 PM
Old School Olds
Sure. The 2nd pic looks like cracks, but those are just scratches.
Old Mar 28, 2016 | 07:18 AM
First, every single 1969 Cutlass that left the factory had an air deflector (not an "air dam" under the front bumper. It was two pieces, a flat part that closed out the gap between the bumper and core support and an angled part that deflected air up into the grille instead of under the car. If that is missing from your car, replace it. These cars did not overheat from the factory, so putting it back to stock is a good place to start.
Old Mar 28, 2016 | 07:50 AM
1969Hurst's Avatar
I think Joe hit the nail on the head. I do not know if you are running a stock radiator but in a stock scenario there are 'several' pieces that are used to close gaps around the radiator area and all of them indeed do help more than you would think. I think all should be listed in a 1969 Cutlass assembly manual.
Old Mar 28, 2016 | 11:46 AM
huskerala's Avatar
Air Dam
Thanks to all. I need to pull my car out of storage and take a good look. Besides the missing fan shroud, I'm guessing that I'm missing the deflector and dam. I may be giving Tru-blue a call on his parts...
V/R
Old Apr 3, 2016 | 12:20 PM
huskerala's Avatar
Not missing
The good news is that my car has the factory air dam. I'll install the shroud this week and have my radiator flushed and checked as a precaution. Thanks for your help.
navvet
18
Nov 19, 2014 04:37 PM
c-towndave
Aug 31, 2014 06:02 AM
ros6872
Jul 18, 2013 09:33 AM
CaptOharry
Body work
Feb 12, 2012 06:52 AM
arodenhiser
Jun 25, 2010 02:53 AM
