Rims interchange
Old Mar 7, 2016 | 04:51 PM
chucky617's Avatar
Rims interchange
My research so far states that the wheel studs were basically the same from the 60's-80's. But can anyone tell me if a set of aftermarket rims from a 1986 cutlass would fit on a 1972 cutlass? I would think they probably would.
Thanks!!!
Old Mar 7, 2016 | 06:25 PM
droptopron's Avatar
delete
They will. Same bolt pattern, 5x4.75, assuming you are talking a RWD '86 Cutlass.
Old Mar 8, 2016 | 05:08 AM
Every single RWD Cutlass/F-85/442/Vista Cruiser from 1964-1988 used the same 5 x 4.75" bolt circle. Every single one used wheels with near zero offset. The only minor issue is that for 1964-69, cars with factory four wheel drum brakes USUALLY (but not always) came with wheels that will not clear disk brake calipers.
Old Mar 8, 2016 | 10:08 AM
jpc647's Avatar
They will fit, but they are narrower. I had newer wheels on my car, and the tires were smaller, the car felt like it had tons of power, but it doesn't. ha.
Old Mar 8, 2016 | 09:07 PM
chucky617's Avatar
Thumbs up Thanks to everybody
Thanks everyone for the great response!!!
LJA72
Jan 31, 2014 08:02 PM
grindlecrew
Mar 2, 2013 04:19 PM
CutlassLegend
Care and Appearance
Aug 6, 2011 11:08 PM
