Rims interchange
Rims interchange
My research so far states that the wheel studs were basically the same from the 60's-80's. But can anyone tell me if a set of aftermarket rims from a 1986 cutlass would fit on a 1972 cutlass? I would think they probably would.
Thanks!!!
Thanks!!!
Every single RWD Cutlass/F-85/442/Vista Cruiser from 1964-1988 used the same 5 x 4.75" bolt circle. Every single one used wheels with near zero offset. The only minor issue is that for 1964-69, cars with factory four wheel drum brakes USUALLY (but not always) came with wheels that will not clear disk brake calipers.
