Wiring Diagram on how to install 8000 RPM tach in 71 cutlass
Old June 13th, 2016, 04:44 PM
CutOvers Olds Parts Guys
Bee Saint Louis's Avatar
I have an hei system. 71 olds cutlass supreme. i bought this tach without any wiring diagram. Any information would be helpful.
Bee Saint Louis is offline
Old June 13th, 2016, 05:04 PM
Typically power, ground, tach signal and light.
Tach signal connects to the TACH terminal on the distributor.
Power and Ground should be self explanatory. You can typically find a switched power connection on the fuse box, such as the IGN terminal.
Light ties into your dash light wiring.
So you need to determine which of those spade terminals ais power and which is the tach input.
Fun71 is offline
Old June 13th, 2016, 05:21 PM
So far i have the light wire to grey light wire from clock. i have the ground wire. the last two male terminals are what i need to know where pwr and tach wires plug up.
Old June 13th, 2016, 10:33 PM
Smash
smash72's Avatar
I have a Mallory set up which i can't find a terminal for a tach. Diagram reads tie tach wire (green if I remember correctly )to the neg side of the coil. Mine has a terminal block from neg coil mounted on the firewall which makes it easier. Will dig up and post that diagram. Going from memory Dash light/white tach wire, ground/blk tach wire, ignition/red tach wire, neg coil/ green tach wire
smash72 is offline
Old June 14th, 2016, 05:25 AM
Whats the worst that can happen if I incorrectly hook up tach and power wires?
Old June 14th, 2016, 06:12 AM
edzolz's Avatar
The smoke gets out. Smoke is what makes it work. Typically green is the tach signal wire, black is ground, red is power, and blue (or grey) is light.
edzolz is offline
Old June 14th, 2016, 06:34 AM
Perhaps contact the manufacturer? There aren't too many sources for that aftermarket Olds tach. The problem is that the ground and light terminals are obvious, but the two spade terminals are unlabeled. On will connect to power and one to the "-" terminal of the coil (or the TACH terminal of an HEI), but you don't know which is which.
joe_padavano is offline
Old June 14th, 2016, 09:42 AM
4speed455's Avatar
Looks like the tach that GM Sports Salvage sells. I would give them a call.
http://www.gmsports.com/content/1968...***-tachometer
4speed455 is offline
Old June 14th, 2016, 12:48 PM
72 Olds CS
RetroRanger's Avatar
^^^this once the magic smoke has been released electronics never work again w out replacement parts.....
RetroRanger is offline
Old June 14th, 2016, 12:52 PM
I'm sure you know that it is being repro'd now... at least for cars on your side of the pond.
Old June 14th, 2016, 03:22 PM
Talked with GM Sports. They directed me to the guy who makes the tachs. He walked me through the install.
HonestDave
September 10th, 2015 01:53 PM
Alex72cutty
December 25th, 2014 06:58 PM
71-442
June 17th, 2013 03:34 PM
Thor-HoG
June 12th, 2012 01:28 PM
oldzy
September 10th, 2009 05:23 AM
Quick Reply: Wiring Diagram on how to install 8000 RPM tach in 71 cutlass
