Wire harness
Old Mar 4, 2025 | 04:48 PM
Blue64oldsguy's Avatar
Wire harness
Trying to unplug wire harness on my 64 cutlass from engine at the firewall. Any advice?
Old Mar 4, 2025 | 09:30 PM
cfair's Avatar
First, unpower the system by disconnecting the battery. Then if something’s broken, it won’t arc & short out.
Look carefully at the connector you’re interested in, GM generally had some ways to disconnect individual wires or groups at bulkheads as the case may be.
If you see some plastic with slots and spring loaded tabs, that’s a clue. The electrical connection system GM used in 1964 was called “Packard 56”. Google that and you’ll figure out what you want to know.
Hope that helps,
Chris
Old Mar 5, 2025 | 09:12 AM
67OAI's Avatar
Old(s)GuysRule
Will this help?
skyhigh
Sep 2, 2022 05:07 AM
oldsmoboogie
Mar 12, 2021 02:55 PM
70-455
May 22, 2020 12:58 PM
therobski
Sep 11, 2013 05:26 PM
DRXOLDS
Apr 24, 2011 07:52 PM
