Window crank failure 😡
Old Jul 2, 2017 | 11:04 AM
budg's Avatar
My car came with nice fitting window cranks but the guy put ugly ***** on them. I saw how cheap the cranks were selling for so I ordered 4 of them . Out of 4 1 fit ok, but the other 3 were sloppy loose. I exchanged them and the 3 that I exchanged were sloppy as well. Now I am wondering if they are just junky . It appears the hole for the spline just isn't deep enough. I'm at wits end. The ones I pulled off were pretty scratched up. What have you guys been doing for window cranks.
Old Jul 2, 2017 | 11:53 AM
Using stock ones. Never had a problem.
Old Jul 2, 2017 | 12:07 PM
budg's Avatar
Where do you get them from? I've used good mark , Dorman and oer without any luck. My next stop is gonna be eBay.
Old Jul 2, 2017 | 12:26 PM
joesw31's Avatar
I may have some excellent original ones. PM, if interested
Old Jul 2, 2017 | 12:37 PM
budg's Avatar
Pm sent
Old Jul 2, 2017 | 04:37 PM
Dorman used to sell replacement GM **** kits. I used them many years ago and they work great. They used to come in colors of black, clear, and white.
Old Jul 2, 2017 | 05:02 PM
RetroRanger's Avatar
72 Olds CS
This one ofthoseitems where good used original is best, lots of complaints about the repops not fitting well and stripping
Old Jul 2, 2017 | 05:16 PM
budg's Avatar
Yeah, after doing some research my experience is pretty much the norm with those window cranks. You would think after all this time they would make some effort to fix the problem.
Old Jul 3, 2017 | 10:31 AM
70Post's Avatar
You could give Ames Performance Engineering a call (Pontiac repro parts). They show a more expensive repro window crank (PN F184KD - $15 ea.) that they claim is more correct in terms of fitment, spline size, etc. I've talked with them before on these but have not yet tried them out. They maintain fairly good "notes" on their computer system that the sales people can access and during a conversation with them awhile back (I had specifically called them about these window cranks) they referred to their computer system notes......said they had sold MANY of these and were not getting any negative feedback on them.
Sure, I realize many vendors use the line "That's the first we've ever heard of that problem" or something to that effect when you contact them to ask about a problem with a part BUT Ames has a fairly good rep when it comes to providing good descriptions on their repro parts.
They also sell cheaper versions so it's not like the PN F184KD is the usual repro window crank that they've just jacked the price up on in an effort to convince you it's "better".
Does your car have reproduction door panels on it? If so, whose panels?
Old Jul 3, 2017 | 11:07 AM
budg's Avatar
Definately worth pondering. My door panels are stock .
Old Jul 3, 2017 | 11:19 AM
scottv442's Avatar
Maintained
is the factory tension spring installed behind the cranks?
Old Jul 3, 2017 | 11:26 AM
70Post's Avatar
OK - figured I would ask......Legendary's panels seem to be a bit thicker (ie - the panel board is thicker/stiffer compared to originals) which can exacerbate the problem with shorter splines on the repro cranks.
Old Jul 3, 2017 | 11:28 AM
budg's Avatar
No springs were installed . The originals were fine as far as fit.
Old Jul 3, 2017 | 12:39 PM
dc2x4drvr's Avatar
I just ordered the Ames window cranks, the repros I've tried are junk..
Old Jul 4, 2017 | 04:42 AM
I got new cranks with the new interior I ordered from Legendary. I had no problems at all, seem just fine though I didn't know of any problems to look for. I will check them again.
Old Jul 4, 2017 | 11:22 AM
joesw31's Avatar
PM sent
Old Jul 4, 2017 | 06:20 PM
garage goat2's Avatar
Where did you get the ones in question?
Old Jul 5, 2017 | 07:34 AM
cutlassjoe's Avatar
I ordered a set of window cranks from Fusick last year and they fit like crap. I used the better ones for the front and the other two in the back. It's hard to find ones that fit properly. My original ones were old and discolored I wished I would have kept them because they at least functioned properly.
Old Jul 5, 2017 | 07:50 AM
budg's Avatar
I got them at Summit and they were fine with the exchanges. Don't fault them.
Bernhard
Nov 24, 2022 09:12 AM
bob p
Apr 10, 2015 01:55 PM
Bernhard
Jan 6, 2013 09:27 PM
sx455raidercelticfan
Nov 23, 2010 05:45 AM
phill_ratrodv8
Feb 25, 2008 02:31 PM
