Why could I not post pics?
It says I can do so but when I placed my ad the area that should have a place to clik doesn't have a box to check or any way to post attachments
I know many here would like to see my rare cars
Thank You!John
![Frown](https://classicoldsmobile.com/forums/images/smilies/frown.gif)
I have looked all over for "advanced"
couldn't find it. the area/box for attach files just shows: Valid file extensions: bmp doc gif jpe jpeg jpg pdf png psd txt wmv zip. Nothing else and nothing will click.Thank you
There is "attach files" that has nothing that will click
under it it reads:Valid file extensions: bmp doc gif jpe jpeg jpg pdf png psd txt wmv zip.Nothing will click. No box comes up as it usually would anywhere else I have sent pics. Nothing says: "manage attachments". Could that function be disabled even though it shows: "You may post attachments"?Thank you
click "post reply"
the line which has "fonts" to the right is a smilely face, next to it is the paper clip
click the paper clip and a box comes up the browse, click the box and find your pic. copy , click the "Host it" box and paste to your post.
Gene
Gene
Try doing the last one. Click "Post Reply" the box at the bottom left. When the window opens it has a spot where you can put a title if you want. Under that it says "Message" and there is a box you post tyour question. ABOVE this box you will see where it says "Fonts" to the right of that is "Sizes' to the right of that is an A underlined then comes a white smiley face and just right of that is the paperclip and if you click that a window should open where you can browse your computer for pics. Be sure to click the open window to get them loaded to the site and then make sure you click the upload button. Then you should have a pic in your reply post.
Don't use the "post quick reply" button at the bottom center.
Use the "post reply" button at the bottom left.
Scroll all the way to the bottom of the page. (below the "submit reply" button). There you will find "manage attachments."
jeffs 89 cutlass salon
November 5th, 2007 05:48 PM
