Why Is This Chain Here?
It doesn't look factory to me. I don't remember my '70 or '71 convertibles having this. Any ideas?
It wasn't put there by the factory, but it could possibly be there because it was left behind at the factory, but not likely. What are the 2 ends attached to? Can you pull it out, or is it stretched tightly and affixed in place? I can see what looks like a screw and washer in line with the chain, but the screw and washer don't look like they belong there either.
Could be someone left it there after pulling the body off the frame or something.
Does it have any tension on it?
Does it tighten up when you raise and lower the top?
Did your car have a lot of rust originally?
The chain has no tension. It hangs down about an inch or two. When I got the car (1999) it had/has no rust, it was restored, but not a body off restoration. It does not change at all when putting the top down. It is bolted into the rear back seat support panel.
Closer up pics of where it is attached:
Naw, car has spent it's whole life in Pennsylvania and Michigan. Too loose to be body stiffener. I think I will remove it, just wanted to check with others to make sure I wasn't missing something obvious.
There was a big speaker in the trunk when I bought the car. First thing I got rid of...
The speaker security thing does make sense then.
It was in the trunk area. In one of my posts I mentioned that it was attached to the back seat support panel.
russell-t
Jun 19, 2012 05:48 AM
